Programming and flashing the DUE without the Arduino IDE
Hello,
I would like to do some bare metal C programming on the DUE, meaning I want to program directly the SAM3X8E without any of the Arduino IDE and stuff. I know it would be way easier using the IDE, but I would like to learn to do without it.
I already worked on a STM32 in C before, using the Keil IDE which was doing all the compiling and flashing for me, that is why I want to learn to do it without an IDE.
I suppose I should use the gcc arm-none-eabi tool-chain to compile the C code (in command line or using another IDE I don't know), but I can't figure how to flash the controller after that. Which USB port should I use? And which tool should I use to flash it?
Thanks
Atmel has a couple of tools: AS6 and SAM-BA. You can use also bossac by Shumatech and even Keil. For the AS6 and Keil you'll need a hardware programmer like SAM-ICE and the pin adapter. The other two are more for direct flashing via USB (programming or native port). Regards,
-p
I'll try flashing via USB, since I don't want to buy more hardware, so I'll look into bossac.
Thanks for the help.
Regards
