programming Arduino remotely via XBEE
I am trying to remotely program an Atmega328 with UNO bootloader using an XBEE. For the reset line, I use XBEE's I/O line passing, with the programming done via the XBEE's serial link. The /RST, TX, and RX signals at the transmitting XBEE and remote Arduino show proper levels and polarity. But I get an error message (a sync error after 3 retries) when trying to program it using Arduino's AVR to write to the transmitting XBEE. On other projects that are programmed in the usual way, I have seen this message when there was a problem with reset levels or timing.
Does anyone know of either: 1) a way to program Atmega328s remotely via XBEE or 2) a reference document for the bootloader/AVR with a description of the loading process, especially timing and state diagrams?
  • I am using the most recent releases of Arduino and bootloader.
  • Programming was tried at 9600 and 57600. XBEE to XBEE communication was fully verified at both baud rates, but with no programming success.
  • Reset at remote XBEE came from an I/O thru a 0.1uF cap to the /RST pin pulled up with 10K. A direct connection between XBEE and /RST was also tried.
Which XBees are you using?
I am using series1 XBEEs (not ZIGBEE).
All the tutorials I've seen that claim that wireless programming of the Arduino is possible used Series 2 models.
There are instructions for programming via series 1 XBEEs like Adafruits’ Xbee Adapter - wireless Arduino programming. This is identical to what I have been trying to do, except Adafruit only got it to work with the Duemilanove bootloader and I need to make this work with the UNO bootloader - or at least understand why it doesn’t. That’s why I was looking for documentation on that bootloader. I want to compare my scope traces with the bootloader’s protocol and timing requirements.
If anyone has been able to remotely program an Atmega328 with UNO bootloader via series 1 XBEE, I could use some advice.
Found the problem and solution:
Series 1 XBEEs seem to get unreliable above 57600 bps in my tests. And the UNO bootloader runs at 115200 bps with no option of changing that speed. Using Adafuit’s bootloader https://www.adafruit.com/products/123 everything runs well at 57600 bps. Now the procedure on this page Xbee Adapter - wireless Arduino programming works.
