Hello,
I have just bought an Arduino UNO Wifi, and am trying to program it, using Arduino IDE 1.8.8 on a Mac. I was at first confused by the options in the IDE, under ‘Boards’: there is an ‘Arduino UNO Wifi’ under ‘Arduino AVR Boards’, and also an ‘Arduino UNO Wifi Rev2’ under ‘Arduino megaAVR boards’. I tried both, but only the latter compiles when I start with the ‘Blink’ example. On the underside of the board it says ‘Arduino UNO Wifi rev2’, so that makes sense, I guess.
But when I try another example, using the Wifi libraries, I get an error.
The sketch is the ‘HueBlink’ example:
/* HueBlink example for ArduinoHttpClient library
Uses ArduinoHttpClient library to control Philips Hue
For more on Hue developer API see http://developer.meethue.com
To control a light, the Hue expects a HTTP PUT request to:
http://hue.hub.address/api/hueUserName/lights/lightNumber/state
The body of the PUT request looks like this:
{"on": true} or {"on":false}
This example shows how to concatenate Strings to assemble the
PUT request and the body of the request.
modified 15 Feb 2016
by Tom Igoe (tigoe) to match new API
#include <SPI.h>
#include <WiFi101.h>
#include <ArduinoHttpClient.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
/////// Wifi Settings ///////
char ssid[] = SECRET_SSID;
char pass[] = SECRET_PASS;
int status = WL_IDLE_STATUS; // the Wifi radio's status
char hueHubIP[] = "192.168.178.60"; // IP address of the HUE bridge
String hueUserName = SECRET_USER; // hue bridge username
// make a wifi instance and a HttpClient instance:
WiFiClient wifi;
HttpClient httpClient = HttpClient(wifi, hueHubIP);
//Initialize serial and wait for port to open:
while (!Serial); // wait for serial port to connect.
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// you're connected now, so print out the data:
Serial.print("You're connected to the network IP = ");
IPAddress ip = WiFi.localIP();
Serial.println(ip);
sendRequest(3, "on", "true"); // turn light on
delay(2000); // wait 2 seconds
sendRequest(3, "on", "false"); // turn light off
void sendRequest(int light, String cmd, String value) {
// make a String for the HTTP request path:
String request = "/api/" + hueUserName;
request += "/lights/";
request += light;
request += "/state/";
String contentType = "application/json";
// make a string for the JSON command:
String hueCmd = "{\"" + cmd;
hueCmd += "\":";
hueCmd += value;
hueCmd += "}";
// see what you assembled to send:
Serial.print("PUT request to server: ");
Serial.println(request);
Serial.print("JSON command to server: ");
// make the PUT request to the hub:
httpClient.put(request, contentType, hueCmd);
// read the status code and body of the response
int statusCode = httpClient.responseStatusCode();
String response = httpClient.responseBody();
Serial.println(hueCmd);
Serial.print("Status code from server: ");
Serial.println(statusCode);
Serial.print("Server response: ");
Serial.println(response);
The error I get when I compile this is:
/Users/pmansvelder/Documents/Arduino/libraries/WiFi101/src/WiFiMDNSResponder.cpp:26:21: fatal error: strings.h: No such file or directory
compilation terminated.
exit status 1
Fout bij het compileren voor board Arduino Uno WiFi Rev2
I have updated all the libraries, but to no avail; does anybody have a suggestion?
Peter Mansvelder
