Programming Assistance
#include <IRremote.h>
#include <Boards.h>
#include <Firmata.h>
#include <FirmataConstants.h>
#include <FirmataDefines.h>
#include <FirmataMarshaller.h>
#include <FirmataParser.h>
#include <Wire.h>
#define IR_USE_TIMER2     // tx = pin 9
IRsend irsend;
const int  Down_buttonPin = 5;
int shotsLeftCheck = 35; // Check How Many Shots Left
int down_buttonState = 0;         // current state of the trigger
int down_lastButtonState = 0;     // previous state of the trigger
const int Game_start = 4; // Starts Game
int Game_startState; // Shows Game On or Off
int pincheck[54];
int prevpincheck[54];
int Score_Pins1 = 22;
int Score_Pins2 = 23;
int Score_Pins3 = 24;
int Score_Pins4 = 25;
int Score_Pins5 = 26;
int Score_Pins6 = 27;
int Score_Pins7 = 28;
int Score_Pins8 = 29;
int Score_Pins9 = 30;
int Score_Pins10 = 31;
int Score_Pins11 = 32;
int Score_Pins12 = 33;
int Score_Pins13 = 34;
int Score_Pins14 = 35;
int Score_Pins15 = 36;
int Score_Pins16 = 37;
int Score_Pins17 = 38;
int Score_Pins18 = 39;
int Score_Pins19 = 40;
int Score_Pins20 = 41;
int Score_Pins21 = 42;
int Score_Pins22 = 43;
int Score_Pins23 = 44;
int Score_Pins24 = 45;
int Score_Pins25 = 46;
int Score_Pins26 = 47;
int Score_Pins27 = 48;
int Score_Pins28 = 49;
int Score_Pins29 = 50;
int Score_Pins30 = 51;
int Score_Pins31 = 52;
int Score_Pins32 = 53;
const int Game_Reset = 2;
int Score = 0000;
int a = 100;
bool bPress = false;
String pin_str = "";
float current_time = millis();
float pintimeout[54];
float pin_timeout_default=500;
  for (int i=0;i<54;i++) {
    pincheck[i]=0;
    prevpincheck[i]=0;
    pintimeout[i]=0;
  for (int ii = 2;ii<=sizeof(pincheck)/sizeof(pincheck[0]);ii++){
    pinMode(ii,INPUT);
  pinMode(Game_Reset, OUTPUT);
  digitalWrite(Game_Reset, LOW);
  pinMode( Down_buttonPin , INPUT_PULLUP);
  pinMode(Game_start, OUTPUT);
  Serial.println(Score);
void pin_status()
  for (int i=3;i<54;i++) {
    pincheck[i]=digitalRead(i);
   //  pincheck[Game_start] = digitalRead(Game_start);
   pin_status();
   for (int i=22;i<54;i++) {
    //if (pincheck[i]==HIGH && prevpincheck[i]!=HIGH) {
    if (pincheck[i]==HIGH && prevpincheck[i]!=HIGH && current_time >= pintimeout[i] && pincheck[Game_start] != HIGH ) {
      Score = a + Score;
      pintimeout[i] = current_time + pin_timeout_default;
   if (pincheck[Game_start] == HIGH){
        delay(50);
        Score = 0000;
        checkDown();
        delay(5);
      //Serial.println(Score);
    while (Serial.available()){
    char in_char = Serial.read();
    if (int(in_char)!=-1){
      pin_str+=in_char;
    if (in_char=='\n'){
      int pin_num = pin_str.toInt();
      pincheck[pin_num] = !pincheck[pin_num];
      digitalWrite(pin_num, pincheck[pin_num]);
      if (pincheck[pin_num]==0){
      pin_str = "";
  for (int i=5;i<54;i++) {
    prevpincheck[i]=pincheck[i];
void checkDown()
  down_buttonState = digitalRead(Down_buttonPin);
    if(shotsLeftCheck <= 0){
      digitalWrite(Game_Reset, HIGH);
    if(shotsLeftCheck <= 0 || shotsLeftCheck >35) {
  // compare the buttonState to its previous state
  if (down_buttonState != down_lastButtonState) {
    // if the state has changed, increment the counter
    if (down_buttonState == LOW) {
      // if the current state is HIGH then the button went from off to on:
       irsend.sendNEC(0x20DF8877, 32);
       shotsLeftCheck--;
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  down_lastButtonState = down_buttonState;
I am having an issue that the ir transmitter will only transmit about 1/5 button presses. I have checked delays and none should be affecting this. I have the ir sensor hooked into pin 9 with a 100ohm resistor then to ground. I am using a mega2560.
Why have you included this line? It is set in the library for the IR!
