Programming at 8MHz vs. 16MHz clock speed
Hello,
I have an arduino nano and I've changed the clock speed from 16MHz to 8MHz to save power. The problem is that my code involves a distance sensor and millis() so it runs differently. In general, what things must be considered when programming at a slower clock speed like 8MHz for example?
Thank you
The bootloader baud rate is halved.
For everything else the best choice is to use a board entry with the correct clock speed.
