Hello, I built the parallel programmer and succesfully programmed the atmega8 bootloader with uisp. I am now trying to program the atmega168 but keep getting a lot of flash errors.
Any advice?
Chuck
uisp -dpart=ATmega168 -dprog=dapa -dlpt=0x378 --wr_lock=0xFF Atmel AVR ATmega168 is found. Writing lock bits ... Reinitializing device Atmel AVR ATmega168 is found.
Lock Bits set to 0xff
uisp -dpart=ATmega168 -dprog=dapa -dlpt=0x378 --wr_fuse_l=0xc7 --wr_fuse_h=0xdf --wr_fuse_e=0x08 Atmel AVR ATmega168 is found.
Fuse Low Byte set to 0xc7
Fuse High Byte set to 0xdf
Fuse Extended Byte set to 0x08
uisp -dpart=ATmega168 -dprog=dapa -dlpt=0x378 --erase --upload --verify if=bootloader_v5_6\ATMegaBOOT_168.hex
Uploading: flash ... flash error at address 0x13fd: file=0x00, mem=0xff flash error at address 0x13fe: file=0x0a, mem=0xff flash error at address 0x13ff: file=0x00, mem=0xff flash error at address 0x1400: file=0x09, mem=0xff flash error at address 0x1401: file=0x00, mem=0xff flash error at address 0x1402: file=0x09, mem=0xff flash error at address 0x1403: file=0x00, mem=0xff flash error at address 0x1404: file=0x52, mem=0xff flash error at address 0x1405: file=0x3a, mem=0xff flash error at address 0x1406: file=0x00, mem=0xff flash error at address 0x1407: file=0x47, mem=0xff flash error at address 0x1408: file=0x3a, mem=0xff flash error at address 0x1409: file=0x00, mem=0xff flash error at address 0x140a: file=0x42, mem=0xff flash error at address 0x140b: file=0x3a, mem=0xff flash error at address 0x140c: file=0x00, mem=0xff flash error at address 0x140d: file=0x01, mem=0xff flash error at address 0x140e: file=0x00, mem=0xff flash error at address 0x140f: file=0x00, mem=0xff flash error at address 0x1410: file=0x00, mem=0xff flash error at address 0x1411: file=0x00, mem=0xff
uisp -dpart=ATmega168 -dprog=dapa -dlpt=0x378 --wr_lock=0xCF Atmel AVR ATmega168 is found. Writing lock bits ... Reinitializing device
Atmel AVR ATmega168 is found. Warning: lock bits write=0xCF read=0xFF
Lock Bits set to 0xcf
