Programming atmega328p with arduino mega
i'm wanting to program an atmega328p with an arduino mega. All of the tutorials i've seen use the uno. I would also like to use the 8 Mhz internal clock if possible
Anything that runs on an Uno will run on a Mega. You will likely have to change some wiring and pin assignments, though.
This is the best tutorial: Gammon Forum : Electronics : Microprocessors : How to make an Arduino-compatible minimal board
If you mean on the target ATmega328, that is the factory default for a new chip. But don't forget to unset the factory default divide-by-eight fuse CKDIV8.
The MiniCore core makes it easier to select the 8MHz internal clock (and many other) options. It is what I use along with the Arduino as ISP sketch to bootload and program my stand alone mega328 processors. The GitHub page includes installation instructions.
