Programming atmel 368 with USBasp
Hi I have made my own board with atmega328p-pu they have the bootloader already and I have been able to program the blink thru an arduino but I have not been able to use USBasp. I have try it on linux and windows with 2 homemade boards and 1 arduino uno and I have had the same result. its seems that arduino ide doesn't see the programer because it doesn't let me chose serial port. I installed the drivers on windows. ide response. avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
|500x320
The usb asp does not create a serial port, it is an isp programmer, not a serial adapter.
You can use it to burn bootloader, and "upload using programmer"
I try both no one work.
