Programming ATTiny with Arudino (Hi Low Tech) Enabling Internal Pullup Resistors
Hi Gang
I'm programming an ATTiny with Arduino (Hi Low Tech) and was wondering if I can enable the internal pullup resistors with...
pinMode(2, INPUT_PULLUP);
rather than...
pinMode(2, INPUT);
digitalWrite(2, HIGH);
I don't want to damage anything.
Cheers
Jase :slight_smile:
You won't damage anything.
But the "internal pullup" thing is, in my opinion, "hokey"; they're weak.
Real resistors are solid and inexpensive enough, 10kΩ.
But since the I/O pins are Inputs by default, in setup() pinMode(pin, INPUT); isn't necessary.
"hokey"? They're all that is needed for button presses.
"Weak", not many mA of high output drive.
Use depends on the application.
Hi Guys
Thanks for getting back to me. I'm more concerned as to whether the ATTiny will get the line of code...
and enable the internal pullups.
Cheers
Jase :slight_smile:
I cannot answer the MIT cord, but tthd answer for this core is definitely YES:
/arduino-tiny/
Ray
