Programming button to begin LED Matrix Pattern
I'm working on a school project with some fellow classmates, and we have to build an intelligent square stepping mat that illuminates specific patterns for a person to follow similar to the game Simon says. The mat is a 10x4 LED matrix essentially, and we're using a decade counter to implement the matrix and illuminate different patterns. We've got the code for the first pattern sequence to compile and run properly, however, the problem we're running into is we need to implement a button that tells the pattern to begin, instead of it running on it's own when the arduino is connected.
(We're trying to make this user friendly for a client and I'm sure the last thing they want to do is sift through C++ code and change the pattern manually in the Arduino IDE.).
We would also like to implement other patterns into the code and make it so that each time the pushbutton is pressed, a new pattern shows up on the mat.
For example, we would like to cycle through the patterns and return to the first pattern after all the patterns have been displayed on the matrix by pushing the button.
10x4_MATRX.ino (1.85 KB)
Welcome to the forum
Please follow the advice on posting code given in Read this before posting a programming question in order to make your sketch easy to read, copy and test
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
If the code exceeds the 9000 character inline limit then attach it to a post
The attached code in original post
//10x4 LED Matrix w/ 4017 IC
//Made by Dom Johnson
//03.22.2021
int clock = 9; //clock pin
int reset = 8; //reset pin
int x; // x,y for the loop
int y; // x,y for the loop
#define led0 {B010,B100}
const int numPatterns = 16;//this is the number of patterns you want to display
byte patterns[numPatterns][8]= {led0};//pattern order
int buttonState = 0;
 DDRD=B11111111;// this is a commed that makes pins 0-7 outputs
 //simple stuff here
 pinMode(4, INPUT);
 pinMode(1, OUTPUT);
 pinMode(clock,OUTPUT);
 pinMode(reset,OUTPUT);
 //reseting the 4017 IC, you have to do this
 digitalWrite(reset,LOW);
 delay(1);
  int loops;
buttonState = digitalRead(4); //read state of pushbutton value
    for(x=0;x<numPatterns-1;x++)
    { // loop over the patterns
       if (digitalRead(4) == HIGH)//Checks to see if button is pressed
       digitalWrite(1, HIGH);//If button is pressed program will loop patterns
       digitalWrite(1, LOW);
      for (int z=0;z<10;z++)
      { //scrolls one bite at a time
        for(int t=0;t<loops;t++)
        {// the delay we get with loops
          for(y=0;y<2;y++)
          {// loops over the array of bytes
     byte temp = patterns[x][y];
     byte temp_2=patterns[x][y];
      PORTD = (temp<<z)+(temp_2>>7-z);//writes digital outputs, Z is for how much bites it need to scroll
       delay(1000);// the time every row is on
       PORTD=B00000000;// all pins are low, fixes the ghosting effect
    // telles the 4017 IC to go to the next row
       digitalWrite(clock,HIGH);
       delay(10);
       digitalWrite(clock,LOW);
  delay(1000); // Delay a little bit to improve simulation performance
First thing I notice is that you are not debouncing the switch. When the switch is pressed it will mechanically 'bounce' which causes a stream of HIGH, LOW, HIGH, LOW, etc before it settles into the new HIGH or LOW state. The CPU is fast enough to see all of these transitions.
Secondly you are using pin 1. This is usually not a good idea as pins 1 and 2 on many Arduino boards are the hardware serial that is connected to the USB.
To implement what you want (multiple patterns) the simplest is to use the switch to increment a counter and use the counter to trigger the change in pattern displayed. Pick a value (say 0) for which there is no pattern displayed. Every time the counter goes +1 (ie, switch has been pressed), it displays the pattern for that number. Every time you increment, check if the highest pattern number + 1 has been reached. If it has, reset the counter back to 0 and start all over again.
Here are some alterations I made to the code. I'm using the DDRD command which makes pins 0-7 outputs. Should I change this to something else because as it is now I'm not able to see the pattern any more after changing the digital pins to 3-7
//03.22.2021
#define pattern1 {B100,B010}
byte patterns[numPatterns][8]= {pattern1};//pattern order
int buttonPin;
 int run;
 run = 0; //starts stopped
 buttonPin = 7; //whatever pin your button is plugged into
 //simple stuff here
 pinMode(7, INPUT);
 pinMode(buttonPin, INPUT_PULLUP);
 delay(1);
  int run;
  int loops;
        if(digitalRead(buttonPin) == LOW) //funcitons based off of button pulling input pin LOW
           if(run == 0)
               run = x;
               run = 0;
        if(run > 0)
                for(y=0;y<2;y++)
          // tells the 4017 IC to go to the next row
             delay(10);
  delay(1); // Delay a little bit to improve simulation performance
Umm.. Isn't that 0 & 1?
-jim lee
This doesn't make any sense. You have a multidimensional array with 16*8 (128) elements and only initialize the first 2 elements:
byte patterns[numPatterns][8] = {pattern1}; //pattern order
You have declared run as a local variable to loop(), didn't initialize it, then test it for 0 if the button is pressed.
  int run;
  int loops;
  if (digitalRead(buttonPin) == LOW) //funcitons based off of button pulling input pin LOW
    if (run == 0)
      run = x;
      run = 0;
Why are you testing x<numPatterns-1? You will never access the last pattern this way.
loops is a local variable you never initialize!!!
        for (int t = 0; t < loops; t++)
