programming code
hi,
i need to generate pwm of 30 hz and turn it off at 20 minutes in arduino nano,
so i used a code to generate 30 hz which is given below but i need code to turn it off
int pin =3;
pinMode(3, OUTPUT);
digitalWrite(pin, HIGH);
delay(16.66);
digitalWrite(pin, LOW);
delay(16.66);
interesting:
delay(16.66);
FYI, because delay() only takes integers (unsigned long), your float is being cast to an uint32_t.
How much precision is needed? A very simple but not very elegant solution is to add a while. 20 minutes is 1200 seconds is 1,200,000 millis.
int pin =3;
 pinMode(3, OUTPUT);
 while (millis()<1200000){
  delay(16.66);
   delay(16.66);
What is the point of defining pin as 3 and then doing pinMode(3, OUTPUT) ?
The cast of 16.66 is probably truncating to the integer 16.
You might try:
const byte pin = 3;
 pinMode(pin, OUTPUT);
    delay(16);
    delayMicroseconds(660);
    delay(16);
  // the stop part
  while(1); // press the reset button to repeat
Note: The maximum value for delayMicroseconds is 16383.
