Programming D6T44L temperature sensor with arduino code
Hello everyone,
I’m trying to program temperature sensor D6T44L to connect it with Arduino.
I found a code already written on a japanese site and I am trying to understand if it works.
The main problem is in the library WireExt.h which seems not work or exist anymore. I will attach the code in the post. Could you please tell which library I could use to replace commands taken from WireExt.h ?
Thanks so much in advance
Omron4x4.ino (1.87 KB)
WireExt.h seems to be a custom extension by that specific programmer. Fortunately it seems to be a simply wrapper code for Wire.h functionality.
The code part
      if (WireExt.beginReception(D6T_addr) >= 0) {
        i = 0;
        for (i = 0; i < 35; i++) {
          rbuf[i] = WireExt.get_byte();
        WireExt.endReception();
is probably equivalent to this code
      if (Wire.requestFrom(D6T_addr, 35) == 35) {
        i = 0;
          rbuf[i] = Wire.read();
