Programming error of aurdino nano
#include <SimpleDHT.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
int pinDHT11 = 2;
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
void displaySensorDetails(void)
sensor_t sensor;
bmp.getSensor(&sensor);
Serial.println("----------Space development nexus satellite miniature----Lets bring Space
down to Earth--------------");
Serial.print (“Sensor: “); Serial.println(sensor.name);
Serial.print (“Driver Ver: “); Serial.println(sensor.version);
Serial.print (“Unique ID: “); Serial.println(sensor.sensor_id);
Serial.print (“Max Value: “); Serial.print(sensor.max_value); Serial.println(” hPa”);
Serial.print (“Min Value: “); Serial.print(sensor.min_value); Serial.println(” hPa”);
Serial.print (“Resolution: “); Serial.print(sensor.resolution); Serial.println(” hPa”);
Serial.println(”----------SDNx real time scientific data---------------”);
Serial.println(””);
Serial.println(“Pressure Sensor Test”); Serial.println(””);
if(!bmp.begin())
/* There was a problem detecting the BMP085 … check your connections */
Serial.print(" SDNx says Ooops, no BMP085 detected … Check your circuit some errors
are there!");
while(1);
/* Display some basic information on this sensor */
displaySensorDetails();
Serial.println("=======Space Development Nexus satellite miniature===real time scientific
data====");
Serial.println(“Sample DHT11…”);
byte temperature = 0;
byte humidity = 0;
byte data[40] = {0};
if (simple_dht11_read(pinDHT11, &temperature, &humidity, data)) {
Serial.print(“Read DHT11 failed”);
return;
Serial.print("Sample RAW Bits: ");
simple_dht11_serial_print(data);
Serial.print(“SDNx says you are genius and every thing is OK: “);
Serial.print((int)temperature); Serial.print(” *C, “);
Serial.print((int)humidity); Serial.println(” %”);
// DHT11 sampling rate is 1HZ.
sensors_event_t event;
bmp.getEvent(&event);
if (event.pressure)
Serial.print(“Pressure: “);
Serial.print(event.pressure);
float temperature;
bmp.getTemperature(&temperature);
Serial.print(“Temperature: “);
Serial.print(temperature);
Serial.println(” C”);
float seaLevelPressure = SENSORS_PRESSURE_SEALEVELHPA;
Serial.print(“Altitude: “);
Serial.print(bmp.pressureToAltitude(seaLevelPressure,
event.pressure));
Serial.println(” m”);
Serial.println("");
Serial.println(“Sensor error”);
Can we please have a clue as to the problem that you are having ?
 Serial.print(" SDNx says Ooops, no BMP085 detected ... Check your circuit some errors
are there!");
There are several long lines that you have used a line feed to wrap the text. This is causing an unterminated line error. Remove the line feeds so the text is all on one line or use \ (backslash) where you want to wrap the line to tell the compiler that the text continues on the next line.
sketch_jan19a:46: error: 'simple_dht11_read' was not declared in this scope
sketch_jan19a:52: error: 'simple_dht11_serial_print' was not declared in this scope
Are those functions in the dht library that you are using? Are they spelled right?
Please read the how to use this forum-please read sticky to see how to properly post code and some advice on how to ask an effective question. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
The warning you can ignore for now.
