Programming Error
Hi guys,
I copied this code from the Arduino website,
the code is used to let the robot turn 90 degrees,
but for some reason it's not working, help please.
This is the page where i got the code:
#include <ArduinoRobot.h>
void setup(){
  Robot.begin();
void loop(){
  Robot.turn(90); //Make the robot turn 90 degrees right
Help us by saying what it should do and what it actually does do
How is the robot powered ?
The code is not working!
I didn't use it on the robot yet.(Alphabot uno)
I just compiled it, and I receive a deferent error message, such as:
Arduino: 1.8.7 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\keyboard.cpp: In member function 'int8_t RobotControl::keyboardRead()':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\keyboard.cpp:49:42: error: 'KEY' was not declared in this scope
   lectura_pul = this->averageAnalogInput(KEY);
exit status 1
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp: In constructor 'RobotControl::RobotControl()':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:26:42: error: 'LCD_CS' was not declared in this scope
 RobotControl::RobotControl():Arduino_LCD(LCD_CS,DC_LCD,RST_LCD){
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:26:49: error: 'DC_LCD' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:26:56: error: 'RST_LCD' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp: In member function 'void RobotControl::begin()':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:36:21: error: 'MUXA' was not declared in this scope
  uint8_t MuxPins[]={MUXA,MUXB,MUXC,MUXD};
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:36:26: error: 'MUXB' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:36:31: error: 'MUXC' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:36:36: error: 'MUXD' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:37:29: error: 'MUX_IN' was not declared in this scope
  Multiplexer::begin(MuxPins,MUX_IN,4);
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:40:10: error: 'BUZZ' was not declared in this scope
  pinMode(BUZZ,OUTPUT);
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:43:2: error: 'Serial1' was not declared in this scope
  Serial1.begin(9600);
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp: In member function 'void RobotControl::analogWrite(uint8_t, uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:65:11: error: 'TKD4' was not declared in this scope
  if(port==TKD4)
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp: In member function 'uint8_t RobotControl::_getTypeCode(uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:82:8: error: 'TKD0' was not declared in this scope
   case TKD0:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:83:8: error: 'TKD1' was not declared in this scope
   case TKD1:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:84:8: error: 'TKD2' was not declared in this scope
   case TKD2:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:85:8: error: 'TKD3' was not declared in this scope
   case TKD3:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:86:8: error: 'TKD4' was not declared in this scope
   case TKD4:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:87:8: error: 'TKD5' was not declared in this scope
   case TKD5:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp: In member function 'uint8_t RobotControl::_topDPortToAPort(uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:122:8: error: 'TKD0' was not declared in this scope
   case TKD0:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:124:8: error: 'TKD1' was not declared in this scope
   case TKD1:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:126:8: error: 'TKD2' was not declared in this scope
   case TKD2:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:128:8: error: 'TKD3' was not declared in this scope
   case TKD3:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:130:8: error: 'TKD4' was not declared in this scope
   case TKD4:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:132:8: error: 'TKD5' was not declared in this scope
   case TKD5:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:133:12: error: 'A11' was not declared in this scope
     return A11;
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp: In member function 'int RobotControl::knobRead()':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:254:22: error: 'POT' was not declared in this scope
  return ::analogRead(POT);
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\helper.cpp: In member function 'void RobotControl::displayLogos()':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\helper.cpp:53:24: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
  _drawBMP("lg0.bmp",0,0);
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\helper.cpp:55:24: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
  _drawBMP("lg1.bmp",0,0);
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\lcd.cpp: In member function 'void RobotControl::_drawBMP(char*, uint8_t, uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\lcd.cpp:164:38: warning: NULL used in arithmetic [-Wpointer-arith]
  if ((file.open(filename,O_READ)) == NULL) {
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
Alphabot uno sounds like it uses a Uno
The keyboard library does not work on a Uno or any board using a 328P processor
That code is for use with the old Arduino Robot Robotics & Drones — Arduino Official Store
Is that what you intend to use it with? If so you need to compile with board type Arduino Robot Control or Arduino Robot Motor.
If not (and the Alphabot uno that Google finds looks nothing like it) you need some different code.
Steve
