programming external 93C66 EEPROM with Arduino UNO
Hi everyone, I am very new to all this and still figuring it all out.
so far I have programmed my Arduino with a sketch for reading/writing of M93Cx6 eeproms and also have Python scripts set up for automation of reading/writing, but the script for writing halts at
"INFO:state - Ready.
here is the web page I've been following.
https://github.com/RiLights/Nissan_skyline_eng_lcd/blob/master/README.md
I have been able to dump the ROM to a .Bin from the EEPROM but cannot write to it with a new modified file.
import sys import argparse
from sky_setup import logging,serial_port
parser = argparse.ArgumentParser() parser.add_argument ("-i", "--input", dest='input_dump', default='temp_eeprom.bin', type=str); args = parser.parse_args()
if args.input_dump: bytedata=[] input_dump = args.input_dump with open(input_dump, "rb") as f: byte = f.read(2) while byte != "":
Do stuff with byte.
if byte: bytedata.append(byte)
byte = f.read(2)
serial_port.write('w') logging.info('State - {}'.format(serial_port.readline()))
for i in bytedata: serial_port.write(i) logging.debug('Byte: {}'.format(serial_port.readline())) logging.info('State - {}'.format(serial_port.readline())) serial_port.close()
this is the python script i am using to write the eeprom with
