Hello, I want to flash my Femtoduino via ISP programmer as I intend to change fuse bits for readout protection.
For this purpose I bought the Arduino ISP R3 Programmer
(Product number A000092).
I installed a clean version of Arduino 1.5.8 IDE and tried to flash the Blink File as described on the aforementioned Arduino ISP page.
As the Femtoduino is usually regarded as Arduino Uno (e.g. here), I used the these settings for flashing.
Unfortunately it does not work but ends with the following error message:
Using Port : usb
Using Programmer : arduinoisp
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\.\libusb0-0001--0x2341-0x0049
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description :
avrdude: programmer operation not supportedavrdude: Using SCK period of 10 usec
CMD: [ac 53 00 00] [00 00 53 00]
avrdude: AVR device initialized and ready to accept instructionsReading | CMD: [30 00 00 00] [00 30 00 1e]
CMD: [30 00 01 00] [00 30 00 95]
################CMD: [30 00 02 00] [00 30 00 0f]
################################## | 100% 0.01savrdude: Device signature = 0x1e950f
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
CMD: [ac 80 00 00] [00 ac 80 00]
CMD: [ac 53 00 00] [00 ac 53 00]
avrdude: reading input file "C:\Users\AppData\Local\Temp\build5136853707081851615.tmp/Blink.cpp.hex"
avrdude: writing flash (1030 bytes):Writing | CMD: [4c 00 00 00] [08 4c 00 00]
#####CMD: [4c 00 40 00] [e0 4c 00 40]
######CMD: [4c 00 80 00] [93 4c 00 80]
#####CMD: [4c 00 c0 00] [01 4c 00 c0]
######CMD: [4c 01 00 00] [81 4c 01 00]
#####CMD: [4c 01 40 00] [00 4c 01 40]
######CMD: [4c 01 80 00] [b7 4c 01 80]
#####CMD: [4c 01 c0 00] [cf 4c 01 c0]
######CMD: [4c 02 00 00] [ff 4c 02 00]| 100% 3.31s
avrdude: 1030 bytes of flash written
avrdude: verifying flash memory against C:\Users\AppData\Local\Temp\build5136853707081851615.tmp/Blink.cpp.hex:
avrdude: load data flash data from input file C:\Users\AppData\Local\Temp\build5136853707081851615.tmp/Blink.cpp.hex:
avrdude: input file C:\Users\AppData\Local\Temp\build5136853707081851615.tmp/Blink.cpp.hex contains 1030 bytes
avrdude: reading on-chip flash data:Reading | ################################################## | 100% 1.91s
avrdude: avr_read(): skipping page 9: no interesting data
avrdude: avr_read(): skipping page 255: no interesting data
avrdude: verifying ...
avrdude: 1030 bytes of flash verifiedavrdude done. Thank you.
Something must have been written to the Femtoduino, as the old bootloader doesn't work anymore.
I would be glad if someone of you might give me some starting help with this.
Thanks a lot.
