Programming for gsm and ultrasonic sensor interfacing
I'am trying to combine a program to interface an ultrasonic sensor and a gsm module
it doesn't work together (though it works perfectly fine when interfacing is done separately )
Also I would like to know what a shield is ..... is it absolutely necessary to use one in this situation???
code
#include <SoftwareSerial.h>
//#include <SoftwareSerial.h>
#define trigger 3
#define echo 4
int time_;
float distance, dist_limit = 20.00;//cms
String pilih;
int buzz = 13;
Serial.begin(9600); // Setting the baud rate of GSM Module
Serial.begin(9600); // Setting the baud rate of Serial Monitor (Arduino)
//RecieveMessage();
delay(100);
pinMode(buzz, OUTPUT);
pinMode(trigger, OUTPUT);
pinMode(echo, INPUT);
digitalWrite(buzz, LOW); //set the buzzer in off mode (initial condition)
{ int c=ultrasound();
if (c==1)
digitalWrite(buzz,HIGH);
if (Serial.available()>0)
SendMessage();
digitalWrite(buzz,LOW);
void SendMessage()
Serial.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
Serial.println("AT+CMGS="+9072433114"\r"); // Replace x with mobile number
Serial.println("Message Send :)");// The SMS text you want to send
Serial.println(pilih);
delay(100);
Serial.println((char)26);// ASCII code of CTRL+Z
int ultrasound(void)
digitalWrite(trigger, HIGH);
delayMicroseconds(10);
digitalWrite(trigger, LOW);
time_ = pulseIn(echo,HIGH);
distance = time_*0.01725;
Serial.println(distance);
if (distance <= dist_limit)
return 1;
return 0;
Why do you send an SMS (or try to) only when:
  1. ultrasound() returned a 1 (the measured distance is less than 20.00 whatevers)
  2. there is serial data to read?
It is that second one that puzzles me.
