I am building a submarine with two thrusters each of which is connected to two servos allowing 360 degrees of motion. I have used the fsolve function in octave to solve the nonlinear system of equations to get the servo angles and thrust needed to create my desired motion. I want the Arduino to take a string input <(x,y,z,roll,pitch,yaw> and run those inputs through fsolve and output the angles and thrusts to be sent to the respective servos and motor controllers. Unfortunately fsolve does not exist in Arduino so I will be trying to program it in based on the source code provided by octave. I am very new to programming in Arduino so any help will be very appreciated. Is this goal achievable?
Paul the inputs will be given as a string. Attached is the current code I have commented where I want to add the fsolve to get the correct outputs to send to the motors and servos.
Just a guess here. But, I’m thinking on a low-end microcontroller you’re going to have to come up with a different method than a brute force numerical equation solver.
Here is a novel idea: the computer that is supposed to send the strings to the Arduino could run Octave, and
