Programming help for MPU6050
Hello, guys. So, this is the project that I am working on. Supposedly, I want to run this one and maintain its straight line movement using MPU6050, but I am really having a hard time coding it, and I badly your assistance.
This is my code for it
// SERVOT based on Hacked Roomba
// Delivers food along straight path to tables 3m or 5m away from Kitchen
// Far Tables  1  2
// Near Tables 3  4
//           Kitchen
// Turns to customer
// Then goes back to the kitchen
// Adjusts course if too near a left or right wall
#include<AFMotor.h>
#include "SR04.h"
// usonic 30deg to right
#define TRIG_PIN1 2
#define ECHO_PIN1 10
// usonic 30deg to left
#define TRIG_PIN2 13
#define ECHO_PIN2 9
// time delay in mS
// 1 meter ==> 42 steps
#define MAXSTEP_NEAR 126  //3m
#define MAXSTEP_FAR 210   //5m
#define TURNTIME 100
#define TURN90TIME 900
#define TURN180TIME 1800
#define FWDTIME 50
#define TOONEAR 15 //cm
SR04 sr1 = SR04(ECHO_PIN1,TRIG_PIN1);
SR04 sr2 = SR04(ECHO_PIN2,TRIG_PIN2);
long usonic_right,usonic_left;
int fwdstep,turning;
const int buttonPin = 1;
int buttonState = 0;
// Table selector 4bit DIP switch connected to analog pins
// analog pin is GND if DIP switch is pressed
int sensorPin1 = A0;    // select the input pin for table 1
int sensorValue1 = 0;  // variable to store the value coming from the sensor
int sensorPin2 = A1;    // select the input pin for table 2
int sensorValue2 = 0;  // variable to store the value coming from the sensor
int sensorPin3 = A2;    // select the input pin for table 3
int sensorValue3 = 0;  // variable to store the value coming from the sensor
int sensorPin4 = A3;    // select the input pin for table 4
int sensorValue4 = 0;  // variable to store the value coming from the sensor
int tablenumber = 1;
int maxstep =0;
AF_DCMotor motor1(1); // left motor
AF_DCMotor motor2(2); // right motor
  // run once at startup
   motor1.setSpeed(255);
   motor2.setSpeed(255);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
fwdstep=0;
turning=0;
  // check if the pushbutton is pressed. If it is, the buttonState is LOW:
  do
     buttonState = digitalRead(buttonPin);
  while (buttonState == HIGH);
  // read the value from the sensor and assign table number
  sensorValue1 = analogRead(sensorPin1);
  if (sensorValue1<100) tablenumber=1;
  sensorValue2 = analogRead(sensorPin2);
  if (sensorValue2<100) tablenumber=2;
  sensorValue3 = analogRead(sensorPin3);
  if (sensorValue3<100) tablenumber=3;
  sensorValue4 = analogRead(sensorPin4);
  if (sensorValue4<100) tablenumber=4;
  if (tablenumber<3)
     maxstep = MAXSTEP_FAR;
     maxstep = MAXSTEP_NEAR;
// Deliver to table
do {
   if (turning==0)
   motor1.run(FORWARD);
   motor2.run(FORWARD);
   delay(FWDTIME);
   usonic_right=sr1.Distance();
   usonic_left=sr2.Distance();
if ((usonic_right>TOONEAR)&&(usonic_left>TOONEAR))
  turning=0;
if (usonic_right<=TOONEAR)
   Serial.print(usonic_right);
   Serial.println("cm ");
  // CCW
   motor1.run(BACKWARD);
   delay(TURNTIME);
   turning=1;
if (usonic_left<=TOONEAR)
   Serial.print(usonic_left);
   Serial.println("cm");
   // CW
   motor2.run(BACKWARD);
   delay(TURNTIME);
   turning=1;
   fwdstep++;
} while (fwdstep<maxstep);
   // turn to face customer
   if ((tablenumber==2)||(tablenumber==4))
   // turn 90deg to table CW
   delay(TURN90TIME);
   motor1.run(RELEASE);
   motor2.run(RELEASE);
   delay(100);
   // turn 90deg to table CCW
   delay(TURN90TIME);
   delay(100);
   // wait for customer to get food and press button
   do
   // turn 90deg to kitchen
   delay(TURN90TIME);
   delay(100);
   delay(TURN90TIME);
   delay(100);
// Return to Kitchen
fwdstep=0;
turning=0;
do {
   if (turning==0)
   delay(FWDTIME);
  turning=0;
  // CCW
   delay(TURNTIME);
   turning=1;
   // CW
   delay(TURNTIME);
   turning=1;
   fwdstep++;
   // turn 180deg to table
   // CW
   delay(TURN180TIME);
   delay(100);
Hi weightless,
I apologise for writing very direct, very clear and straight-forward. It might makes you feel a uncomfortable. May aim is to guide you how to use this forum to finish your project successfully.
Your code has
zero
lines of code about a MPU6050-sensor
My understanding of your posting is:
"can somebody look inside my head and read my thoughts how I want the MPU6050 included to function in my device.
And then develop and test the code that does this.
After finishing all tests post the ready to flash code"
Don't you think this is wayyyy toooo much demanding???
You are the one who wants help. All users here are volunturay and free to decide whoom they help and how much.
To correct the bad impression you have made with your posting you should really carefully read
How to get the best out of this forum
and follow the suggestions made there to re-Edit your first post.
best regards Stefan
this code seems ambitious. a lengthy sequence of operations that repeat a varying # of times.
have you tried testing them individually?
have you verified
  • that the sensing works?
  • that the algorithm to maintain a straight line works?
  • that moving the desired distance works?
it also makes sense to break these steps into sub-functions for the various movements rather than duplicating code, including a sub-function to recognize a button press at any time, possibly to stop
Problem solved. It was just a hardware problem.
