hi there people,
so i FINALLY made a obstacle avoiding robot but i wanted to take it to another level so i decided to add another sensor to the robot. but i am having trouble programming it … so could anyone help me
thnks
//#include <AFMotor.h> //import your motor shield library
#define trigPin 12 // define the pins of your sensor
#define echoPin 13
#include <Servo.h>
Servo servoLeft; // and similar for other ones
Servo servoRight; //
int pos = 0; // variable to store the servo position
Serial.begin(9600); // begin serial communitication
Serial.println(“Motor test!”);
pinMode(trigPin, OUTPUT);// set the trig pin to output (Send sound waves)
pinMode(echoPin, INPUT);// set the echo pin to input (recieve sound waves)
servoLeft.attach(10); // Set left servo to digital pin 10
servoRight.attach(9); // Set right servo to digital pin 9
long duration, distance; // start the scan
digitalWrite(trigPin, LOW);
delayMicroseconds(2); // delays are required for a succesful sensor operation.
digitalWrite(trigPin, HIGH);
delayMicroseconds(10); //this delay is required as well!
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;// convert the distance to centimeters.
if (distance < 25)/*if there’s an obstacle 25 centimers, ahead, do the following: */ {
Serial.println (“Close Obstacle detected!” );
Serial.println (“Obstacle Details:”);
Serial.print (“Distance From Robot is " );
Serial.print ( distance);
Serial.print ( " CM!”);// print out the distance in centimeters.
Serial.println (" The obstacle is declared a threat due to close distance. “)
;Serial.println (” Turning !");
servoLeft.write(0);
servoRight.write(90);
// else {
Serial.println (“No obstacle detected. going forward”);
delay (15);
void turnRight()
;servoLeft.write(180);
servoRight.write(0);
this is my current program and it works fine but the problem is that the robot can only turn in one direction that is the reason i wanted to add another senor so it can turn in both directions
