Programming help needed -IR tachometer
Output in serial monitor generates random numbers automatically even before placing the computer fan 3000 rpm.
I feel the code has some bug . Kindly help fixing it
led (status) ---- pin 12 (connected via 200 ohm resistor)
IR transmitter --- pin 13 (connected via 200 ohm resistor)
IR receiver ---- pin 2 (connected via 10k resistor)
IR leds are fixied facing eachother.
int ledPin = 13;                // IR LED connected to digital pin 13
int statusPin = 12;             // LED connected to digital pin 12
volatile byte rpmcount;
volatile int status;
unsigned int rpm;
unsigned long timeold;
 void rpm_fun()
   //Each rotation, this interrupt function is run twice, so take that into consideration for
   //calculating RPM
   //Update count
      rpmcount++;
   //Toggle status LED
   if (status == LOW) {
     status = HIGH;
     status = LOW;
   digitalWrite(statusPin, status);
   //Interrupt 0 is digital pin 2, so that is where the IR detector is connected
   //Triggers on FALLING (change from HIGH to LOW)
   attachInterrupt(0, rpm_fun, FALLING);
   //Turn on IR LED
   pinMode(ledPin, OUTPUT);
   digitalWrite(ledPin, HIGH);
   //Use statusPin to flash along with interrupts
   pinMode(statusPin, OUTPUT);
   rpmcount = 0;
   rpm = 0;
   timeold = 0;
   status = LOW;
   //Update RPM every second
   //Don't process interrupts during calculations
   detachInterrupt(0);
   //Note that this would be 60*1000/(millis() - timeold)*rpmcount if the interrupt
   //happened once per revolution instead of twice. Other multiples could be used
   //for multi-bladed propellers or fans
   rpm = 30*1000/(millis() - timeold)*rpmcount;
   timeold = millis();
   rpmcount = 0;
   //Write it out to serial port
   Serial.println(rpm,DEC);
   //Restart the interrupt processing
I have attached circuit diagram and output screenshot
You don't want to detach interrupts - at most you want to disable them, and then only for the minimum time necessary around access to the volatile variables. incidentally, status doesn't need to be volatile since it is not used in the main context, except for the redundant initialisation in setup().
Do you have a link to the data sheet for the IR sensor?
