Here you go. The rest of the code works fine including the server
/*********************** Marque's Arduino Controller Example /
/ for questions: marque.l@gmail.com **********************/
In the android app settingsscreen you can set up you IP and port.
For this example you need to call prefix 1 "B" and prefix 2 "C".
#include <Ethernet.h>
#include <HTTPClient.h>
#include <SPI.h>
int imm = 70;
int coil = 50;
int flow = 60;
int und = 65;
int mix = 57;
int hyst = 3;
int hyst1 =6;
int hyst2 =22;
float tempTop;
float tempMid;
float tempBot;
float tempFlow;
float tempRet;
int RecievedString;
int valueB;
int valueC;
String readString = String(20);
int tempPin5 = 5;
int tempPin1 = 1;
int tempPin2 = 2;
int tempPin3 = 3;
int tempPin4 = 4;
int NeutValve = 2; // Valve from neutralizer to Cylinder
int MPump = 3; // Mixer Pump
int MPumpA = 4;// Auto control Mixer
int HeatValve = 5; // Central Heating Main Pump
int ProgOn = 7; //Programmer Heating Demand
int GasOn = 6; // Gas boiler run output
int UndFlor = 8; // Underfloor heating run output
int FlorLiv = 9; // Underfloor Heating Living Room Output Over heat protection
int GasBoiler = 44; // Software boiler output only
int RainPump = 23;// Rain Water Pump
int WaterValve =5;// Fresh Water Valve to Top Tank
int Hotwater =25;// Hot water Demand
int hwaterV = 11;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetServer server(xx); // port to listen on
IPAddress ip(xxx,xxx,xxxx,xxx); // Ip for fixed IP Address
EthernetClient client;
char content_main_top[] = "";
char S11[] = "Boiler on" ;
char S12[] = "Boiler off" ;
char S13[] = "Mixer Pump on" ;
char S14[] = "Mixer Pump off" ;
char S15[] = "Heating Valve on";
char S16[] = "Heating Valve off";
char S17[] = "Turning Underfloor On";
char S18[] = "Turning Underfloor Off";
char S19[] = "Turning All On";
char S20[] = "";
char S21[] = "Manual Control";
char S22[] = "Manual Control";
char S23[] = "Rain Water Pump On";
char S24[] = "Rain Water Pump Off";
char S25[] = "Fresh Water Valve Open";
char S26[] = "Fresh Water Valve Closed";
char S27[] = "Auto Enabled";
char S28[] = "Manual Control";
char S29[] = "Water Valve Open ";
char S30[] = "Water Valve Closed";
char S31[] = "Refresh";
//char S404[] = "Not Found ";
/************************** Setup **********************/
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7,INPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(13,OUTPUT);
pinMode(24,OUTPUT);
pinMode(12,OUTPUT);
Serial.println("Getting IP......");
//Ethernet.begin(mac);
Ethernet.begin(mac,ip);
Serial.print("My IP address: ");
Ethernet.localIP().printTo(Serial);
Serial.print("Gateway IP address is ");
Ethernet.gatewayIP().printTo(Serial);
Serial.print("DNS IP address is ");
Ethernet.dnsServerIP().printTo(Serial);
tempTop = analogRead(tempPin5); //read the value from the Cylinder Top sensor
tempTop = (5.0 * tempTop * 100.0)/1024.0; //convert the analog data to temperature
//Serial.print((byte)tempTop);
//Serial.println(" *C Top Temp");
tempBot = analogRead(tempPin2); //read the value from the sensor Cylinder Bottom
tempBot = (5.0 * tempBot * 100.0)/1024.0; //convert the analog data to temperature
//Serial.print((byte)tempBot);
//.println(" *C Temp Bot");
tempFlow = analogRead(tempPin3); //read the value from the sensor Neutraziler Flow Temp
tempFlow = (5.0 * tempFlow * 100.0)/1024.0; //convert the analog data to temperature
//Serial.print((byte)tempFlow);
//Serial.println(" *C Flow Temp");//send the data to the computer
tempRet = analogRead(tempPin4); //read the value from the sensor Return Temp
tempRet = (5.0 * tempRet * 100.0)/1024.0; //convert the analog data to temperature
//Serial.print((byte)tempRet);
//Serial.println(" *C Return Temp");//send the data to the computer
delay(2000);
//Over Temperature Protection
if (tempFlow > 90)
digitalWrite(HeatValve, HIGH);
digitalWrite(FlorLiv, HIGH);
if (tempFlow < 79)
digitalWrite(HeatValve, LOW);
digitalWrite(FlorLiv, LOW);
// Heating Circulating pump
// New controls
if (tempTop > 45 && digitalRead(GasOn) == HIGH)
else if (tempTop > 45 && tempRet > flow + hyst1)
else if (tempTop < 43 || tempRet < flow - hyst2)
if (tempTop < tempFlow && tempTop < 48)
digitalWrite(hwaterV, HIGH);
else if (tempTop > tempFlow || tempTop > 50)
digitalWrite(hwaterV, LOW);
// Programmer Input
if (digitalRead(ProgOn) == HIGH)
digitalWrite(GasOn, HIGH);
if (digitalRead(GasBoiler) == HIGH)
if (tempTop < 42)
digitalWrite(Hotwater, HIGH);
else if (tempTop > 45)
digitalWrite(Hotwater, LOW);
if (digitalRead(Hotwater) == HIGH)
else if (digitalRead(ProgOn) == LOW && digitalRead(GasBoiler) == LOW && digitalRead(Hotwater == LOW))
digitalWrite(GasOn, LOW);
// Cylinder Circulating Pump Control
if (tempTop > 55 && (tempTop - tempBot >= 7 ))
digitalWrite (MPumpA, HIGH);
else if (tempTop - tempBot <= 4 || tempTop < 50)
digitalWrite (MPumpA, LOW);
// Underfloor Heating Control
if (tempFlow > und + hyst && digitalRead(HeatValve) == HIGH || digitalRead(HeatValve) == HIGH && digitalRead(GasBoiler) == HIGH)
digitalWrite(UndFlor, HIGH);
if (tempFlow < und - hyst && digitalRead(HeatValve)== LOW)
digitalWrite (UndFlor, LOW);
// Neutralizer Valve Control
if (tempTop >(coil + hyst)) // Neutralizer to Cylinder Valve Close Temperature
digitalWrite(NeutValve, HIGH);
if (tempTop <(coil - hyst)) // Neutralizer to Cylinder Open Temperature
digitalWrite(NeutValve, LOW);
// Water Tank Level Control
//if (digitalRead(Control) == HIGH && digitalRead(LowTank20) == HIGH && digitalRead(HighTank30) == LOW)
//digitalWrite (RainPump, HIGH);
//if (digitalRead(Control) == HIGH && digitalRead(LowTank30) == LOW || digitalRead(HighTank90) == HIGH)
//digitalWrite (RainPump, LOW);
//if (digitalRead(Control) == HIGH && digitalRead(LowTank30) == LOW && digitalRead(HighTank40) == LOW)
//digitalWrite (WaterValve, HIGH);
//if (digitalRead(Control) == HIGH && digitalRead(HighTank60) == HIGH)
//digitalWrite (WaterValve, LOW);
checkclient();
