hey.
i have a password kepad and lcd program i want to add to this program servo commands my point is that if the password is correct so the servo will work once at a time (90 degrees) and if the pass word will be wrong the servo remains off
can U add plz to this program the commands that im described above . the program that i have:
#include <Password.h> //Arduino Playground - HomePage
#include <Keypad.h> //Arduino Playground - HomePage
#include <LiquidCrystal.h>
LiquidCrystal lcd(A4, A5, A3, A2, A1, A0);
Password password = Password( "1234" );
const byte ROWS = 4; // Four rows
const byte COLS = 4; // columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = { 9,8,7,6 };// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte colPins[COLS] = { 5,4,3,2, };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
lcd.begin(16, 2);
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
void loop(){
keypad.getKey();
//take care of some special events
void keypadEvent(KeypadEvent eKey){
switch (keypad.getState()){
case PRESSED:
lcd.print("Pressed: ");
lcd.println(eKey);
switch (eKey){
case '*': checkPassword(); break;0
case '#': password.reset(); break;
default: password.append(eKey);
void checkPassword(){
if (password.evaluate()){
lcd.println("Success");
//Add code to run if it works
}else{
lcd.println("Wrong");
//add code to run if it did not work
thanks !
