Hey all i just don’t understand how to fix the problems in my program below any advice would help thanks. Its for sensors reading a certain distance I had to add more to it and it gave me a lot of problems.
// Maps sensor ID (array index) to pin (array value)
const int PING_MAP = {32, 33, 34, 35, 36, 37, 38, 39, 40, 41};
const char input_template = “<+##,+##>”;
// Get serial input from RPi
String serial_input = get_serial_in();
// Process serial input from RPi
process_serial_in(serial_input);
// Process local data to send to RPi
String serial_output = process_serial_out();
// Send serial data to RPi
send_serial_out(serial_output);
String get_serial_in()
Serial.println(“Getting serial buffer”);
// Wait until we have a command to execute
while (true)
// If at least one command is in the serial buffer
if (Serial.available() >= sizeof(input_template) - 1)
// If there’s two or more commands in the buffer
// Get rid of all but one
while (Serial.available() > 2*sizeof(input_template))
Serial.read();
// If there’s less than two commands, grab the full one
char rc;
// Look for the starting character
while ((rc = Serial.read()) != ‘<’)
//rc = Serial.read();
String serial_string;
// While we haven’t read the end character
while ((rc = Serial.read()) != ‘>’)
serial_string += rc;
// serial_string should now be “+##,+##”
return serial_string;
// Else wait for a full command
void process_serial_in(String serial_input)
serial_input.trim();
// serial_input is of the form “+###,+###”
int sign_x = (serial_input[0] == ‘+’) ? 1 : -1;
int sign_z = (serial_input[serial_input.indexOf(’,’)+1] == ‘+’) ? 1 : -1;
String x_str = serial_input.substring(1,serial_input.indexOf(’,’)-1);
String z_str = serial_input.substring(serial_input.indexOf(’,’)+2);
int x = sign_x * x_str.toInt();
int z = sign_z * z_str.toInt();
//Serial.print("X value is “);
//Serial.print(x);
//Serial.print(”| Z value is ");
//Serial.println(z);
String process_serial_out()
String serial_out = “”;
for ( int i = 0; i < sizeof(PING_MAP)/sizeof(int); i++)
serial_out += String(i);
serial_out += ‘,’;
serial_out += String(read_ping(PING_MAP*)/29/2);*
serial_out += ‘;’;*
return serial_out;*
void send_serial_out(String serial_output)
Serial.println(serial_output);*
long read_ping(int pin_number)
pinMode(pin_number, OUTPUT);*
digitalWrite(pin_number, LOW);*
delayMicroseconds(3);*
digitalWrite(pin_number, HIGH);*
delayMicroseconds(10);*
pinMode(pin_number, INPUT);*
long result = pulseIn(pin_number, HIGH);*
delay(25);*
return result;*
void write_motor_commands(int x, int rotz)
left_int = (x + rotz)/100128 + 127;
right_int = (x - rotz)/100128 + 127; -
left_byte = (byte)left_int;*
right_byte = (byte)right_int;*
write_left_motor(left_byte);*
write_right_motor(right_byte);*
void write_left_motor(byte value)
Serial1.write(0xFF);*
Serial1.write(1);*
Serial1.write(value);*
void write_right_motor(byte value)
Serial1.write(2);*
