Programming limit switches & starting
Hello,
I want to make a linear axis using a gearbox motor. I want the motor to start turning clockwise when i press button1 when ever it hits the first limit switch (limitswitch1) the motor needs to turn counterclockwise until it hits the second limitswitch (limitswitch2). now its in rest position again until i press button1. Could someone help me getting started. I dont have much experience with arduino yet.
(edit) I want to use a L298n to control the gearbox motor
Thanks for your time.
fervh13523:
See: File->Examples->02.Digital->Button
See: File->Examples->02.Digital->StateChangeDetction
fervh13523:
Use Google to find an L289n library and look at the examples that come with it.
fervh13523:
fervh13523:
fervh13523:
const int buttonPin = 2;
const int limit1Pin = 5;
const int limit2Pin = 4;
const int ENA       = 9;
const int IN1       = 7;
const int IN2       = 6;
int buttonState = 0;
int buttonPushCounter = 0;
int lastButtonState = 0;
int limit1State = 0;
int limit2State= 0;
pinMode (buttonPin, INPUT);
pinMode (limit1Pin, INPUT);
pinMode (limit2Pin, INPUT);
pinMode (ENA, OUTPUT);
pinMode (IN1, OUTPUT);
pinMode (IN2, OUTPUT);
buttonState = digitalRead(buttonPin);
limit1State = digitalRead(limit1Pin);
limit2State = digitalRead(limit2Pin);
if (buttonState != lastButtonState) {
  if (buttonState == HIGH) {
    Serial.println("on");
    Serial.print("1:");
    Serial.println(buttonPushCounter);
    Serial.println("off");
  delay (50);
  lastButtonState = buttonState;
  if (buttonPushCounter % 1 == 0) {
  analogWrite (ENA, 255);
  digitalWrite(IN1, HIGH);
  digitalWrite(IN2, LOW);
  analogWrite (ENA, 0);
  digitalWrite(IN1, LOW);
so if i upload this code the motor should start spinning when i press button1 right?
Problems on a quick look, you never change 'buttonPushCounter' so it's always 0 and you read the limit switches but do nothing with the values you've read.
But try it, see what it does then report back.
Steve
Make sure your buttons and switches are wired properly. You have configured the pin as INPUT which means you either need a pull-down or a pull-up resistor. It would be easier to configure them as INPUT_PULLUP and wire to ground then you don't need an external resistor.
const int ENA       = 9;
const int IN1       = 7;
const int IN2       = 6;
int limit2State = 0;
void runClockwise()
  Serial.println("Clockwise");
void runCounterclockwise()
  Serial.println("Counterclockwise");
  digitalWrite(IN2, HIGH);
void stopMotor()
  Serial.println("Stop");
    // State Change Detected
    // when i press button1
    // I want the motor to start turning clockwise
      runClockwise();
  // when ever it hits the first limit switch (limitswitch1)
  // the motor needs to turn counterclockwise
  if (limit1State == HIGH)
    // Limit1 Switch Pressed
    runCounterclockwise();
  // until it hits the second limitswitch (limitswitch2). now its in rest position again until i press button1.
  if (limit2State == HIGH)
    // Limit2 Switch Pressed
    stopMotor();
