programming mess up!
well this is the program which i copied from a magazine.......
 #include <SoftwareServo.h>
#include <SoftwareSerial.h>
#include <VirtualWire.h>
SoftwareServo myservo1;
SoftwareServo myservo2;
SoftwareServo myservo3;
SoftwareServo myservo4;
const int numberOfAnalogPins = 4; // how many analog integer values to receive
int data[numberOfAnalogPins]; // the data buffer
int value[numberOfAnalogPins];
// the number of bytes in the data buffer
const int dataBytes = numberOfAnalogPins * sizeof(int);
byte msgLength = dataBytes;
myservo1.attach(9);  //Propeller
myservo2.attach(10);  //Radar
myservo3.attach(8);  // Aeleron
myservo4.attach(12);   // Elevator
Serial.println("Ready"); // Initialize the IO and ISR
vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(2000); // Bits per sec
 vw_set_rx_pin(11);
vw_rx_start(); // Start the receiver
void loop(){
if (vw_get_message((byte*)data, &msgLength))  {    // Non-blocking
Serial.println("Got: ");
if(msgLength == dataBytes){
for (int i = 0; i < numberOfAnalogPins; i++) {
Serial.print("pin ");
Serial.print(i);
Serial.print("=");
Serial.println(data[i]);
value[i]=map(data[i],0,1023,0,179);  // Write into the servo
myservo1.write(value[0]);
myservo2.write(value[1]);
myservo3.write(value[2]);
myservo4.write(value[3]);
delay(10);
SoftwareServo::refresh();   //refresh the servo
else {
Serial.print("unexpected msg length of ");
Serial.println(msgLength);
and this is the error......
 C:\Program Files (x86)\Arduino\libraries\SoftwareServo\SoftwareServo.cpp: In member function 'uint8_t SoftwareServo::attach(int)':
C:\Program Files (x86)\Arduino\libraries\SoftwareServo\SoftwareServo.cpp:27: error: 'digitalWrite' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareServo\SoftwareServo.cpp:28: error: 'OUTPUT' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareServo\SoftwareServo.cpp:28: error: 'pinMode' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareServo\SoftwareServo.cpp: In member function 'void SoftwareServo::write(int)':
C:\Program Files (x86)\Arduino\libraries\SoftwareServo\SoftwareServo.cpp:51: error: 'clockCyclesPerMicrosecond' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareServo\SoftwareServo.cpp: In static member function 'static void SoftwareServo::refresh()':
C:\Program Files (x86)\Arduino\libraries\SoftwareServo\SoftwareServo.cpp:73: error: 'millis' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareServo\SoftwareServo.cpp:106: error: 'digitalWrite' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareServo\SoftwareServo.cpp:108: error: 'TCNT0' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareServo\SoftwareServo.cpp:123: error: 'digitalWrite' was not declared in this scope
what is really confusing is that why does it check 'digitalWrite' in 'SoftwareServo'????? :fearful: :fearful:
SoftwareServo.h, SoftwareSerial.h & VirtualWire.h are libraries. Do you have them installed in your libraries folder? - Scotty
Look in SoftwareServo.h and SoftwareServo.cpp and see if there is a "#include <wiring.h>" include.
If so, change that to "#include <Arduino.h>"
I've checked it out and-
1)Suddenly a notification pops up saying that "VirtualWire-1.27" cannot be used.Library names must contain only basic letters and numbers (ASCII only and spaces, and it cannot start with a numbers.) :fearful:
2)all the libraries are there.
3)SoftwareServo.h has a "#include <WProgram.h>"?
So, rename it.
Which also needs to be changed to Arduino.h.
