Johnnydrumz1:
Hi Marco
Thanks for your reply.
I have the shield set up on the Arduino as per this tutorial…
http://www.youtube.com/watch?v=fdY1wfpomxc
I’m just using the example sketch at the moment. I’d like to be able to change the code so it fires a different midi note on each button.
Heres the example code…
#define KNOB1 0
#define KNOB2 1
#define BUTTON1 2
#define BUTTON2 3
#define BUTTON3 4
#define STAT1 7
#define STAT2 6
byte incomingByte;
byte note;
byte velocity;
int pot;
byte byte1;
byte byte2;
byte byte3;
int action=2; //0 =note off ; 1=note on ; 2= nada
//setup: declaring iputs and outputs and begin serial
pinMode(STAT1,OUTPUT); // declare the LED’s pin as output
pinMode(STAT2,OUTPUT);
pinMode(BUTTON1,INPUT);
pinMode(BUTTON2,INPUT);
pinMode(BUTTON3,INPUT);
digitalWrite(BUTTON1,HIGH);
digitalWrite(BUTTON2,HIGH);
digitalWrite(BUTTON3,HIGH);
for(int i = 0;i < 10;i++)
digitalWrite(STAT1,HIGH);
digitalWrite(STAT2,LOW);
delay(30);
digitalWrite(STAT1,LOW);
digitalWrite(STAT2,HIGH);
delay(30);
//start serial with midi baudrate 31250 or 38400 for debugging
Serial.begin(31250);
//Serial.begin(38400);
//Serial.println(“MIDI Board”);
//loop: wait for serial data, and interpret the message
void loop () {
// Button and knob test functions
if(analogRead(KNOB1) > 512){ digitalWrite(STAT1,HIGH); }
else{ digitalWrite(STAT1,LOW); }
if(analogRead(KNOB2) > 512){ digitalWrite(STAT2,HIGH); }
else{ digitalWrite(STAT2,LOW); }
if(!digitalRead(BUTTON1)){ digitalWrite(STAT1,LOW); digitalWrite(STAT2,LOW); }
else if(!digitalRead(BUTTON2)){ digitalWrite(STAT1,HIGH); digitalWrite(STAT2,LOW); }
else if(!digitalRead(BUTTON3)){ digitalWrite(STAT1,LOW); digitalWrite(STAT2,HIGH); }
else if(!digitalRead(BUTTON4)){ digitalWrite(STAT1,HIGH); digitalWrite(STAT2,HIGH); }
//************** MIDI OUT ***************//
pot = analogRead(0);
note = pot/8; // convert value to value 0-127
if(button(BUTTON1) || button(BUTTON2) || button(BUTTON3))
noteOn(0x95,0x3C,0x45);
while(button(BUTTON1) || button(BUTTON2) || button(BUTTON3));
/while(1);
noteOn(0x90,0x3C,0x00);
//*************** MIDI LOOPBACK *//
if(Serial.available() > 0)
byte1 = Serial.read();
byte2 = Serial.read();
byte3 = Serial.read();
noteOn(byte1, byte2, byte3);
//digitalWrite(STAT1,HIGH);
//digitalWrite(STAT2,HIGH);
// MIDI IN **************//
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
// wait for as status-byte, channel 1, note on or off
if (incomingByte== 144){ // note on message starting starting
action=1;
else if (incomingByte== 128){ // note off message starting
action=0;
else if (incomingByte== 208){ // aftertouch message starting
//not implemented yet
else if (incomingByte== 160){ // polypressure message starting
else if ( (action==0)&&(note==0) ){ // if we received a “note off”, we wait for which note (databyte)
note=incomingByte;
playNote(note, 0);
note=0;
velocity=0;
action=2;
else if ( (action==1)&&(note==0) ){ // if we received a “note on”, we wait for the note (databyte)
note=incomingByte;
else if ( (action==1)&&(note!=0) ){ // …and then the velocity
velocity=incomingByte;
playNote(note, velocity);
note=0;
velocity=0;
action=0;
else{
//nada
void noteOn(byte cmd, byte data1, byte data2) {
Serial.write(cmd);
Serial.write(data1);
Serial.write(data2);
void blink(){
digitalWrite(STAT1, HIGH);
delay(100);
digitalWrite(STAT1, LOW);
delay(100);
void playNote(byte note, byte velocity)
int value=LOW;
if (velocity >10){
value=HIGH;
else{
value=LOW;
//since we don’t want to “play” all notes we wait for a note between 36 & 44
if(note>=36 && note<44)
byte myPin=note-34; // to get a pinnumber between 2 and 9
digitalWrite(myPin, value);
char button(char button_num)
return (!(digitalRead(button_num)));
[/quote]
