No matter how I work it I cannot get pins A6 and A7 assigned as outputs on a Nano. Could someone look ,at my programming and tell me what I am doing wrong. All the pins befor A6 and A7 are low as progra
Connection Setup
PIN COLUMN
D2======C1
D3======C2
D4======C3
D5======C4
D6======C5
D7======C6
D8======C7
D9======C8
D10======C9
D11======C10
D12======C11
D13======C12
D0=====C13
D1=====C14
A4=====C15
A5=====C16
A6=====C17
A7=====C18
GRD====Center col.
4 LEVELS
tier(t)= connect to the LED anode.
1=A0
2=A1
3=A2
4=A3
int column[18]={2,3,4,5,6,7,8,9,10,11,12,13,0,1,A4,A5,A6,A7}; // Declaring LED column pin assignment Bottom to top
int tier[4]={A0,A1,A2,A3}; // Declaring LED tier pin assignment. Bottom to top.
int ledTimeOn1=15;
int ledTimeOff1=15;
int ledTimeOn2=50;
int ledTimeOff2=50;
int ledTimeOn3=1500;
int ledTimeOff3=1500;
int ledTimeOn4=500;
int ledTimeOff4=500;
int tier4=4; // turn this tier on or off.
int tier3=3;
int tier2=2;
int tier1=1;
int allTiers=4; // turn all tiers on or off.
int allColumns=18; //turn all columns on or off
//setting columns to output.
for(int c=0; c<allColumns; c++)
pinMode(column[c], OUTPUT);
//setting tiers to output
for(int t = 0; t<4; t++)
pinMode(tier[t] , OUTPUT);
//TURNS ALL THE columns low.
digitalWrite(column[c], 0); //Turns the columns low.
// Turns each tier on then off from bottom to top.
for(int t=0; t<allTiers; t++)
digitalWrite(tier[t], 1);
delay(ledTimeOn2);
digitalWrite(tier[t], 0);
delay(ledTimeOff2);
delay(ledTimeOn3);
delay(ledTimeOff3);
mmed. Thanks.
