programming new arduino ATMEGA168
I thought I damaged the ATMEGA168 (found out i didn't), But when I used a replacement nothing happened when power was on. I'm guessing i need to go to Tools -> burn bootloader -> ?? what would I use for an arduino diecimila?
I had the same problem. Turned out some of my solder joints weren’t as secure as I thought they were. If it’s a kit, check all your connections to the PCB and make sure they’re all solid. As for burning the bootloader, I can’t help you there. Hope that’s helpful.
Assuming you have a brand-new ATmega168 (not a pre-programmed one), you'll need to burn the boot-loader. Depending on your situation, the easiest programmer to build and use is likely the parallel port programmer.
I had a new Freeduino SB kit and I tried out Blink and such and all was great. I was follong around and hooked up a noise making circut to pin 13 as that was the LED I was blinking. The noise also came on when the LED blinked. I then tweeked the software and tried to re-send the program and got an error, the old blink program kept running though. Then I disconnected the noise maker and still got an error. I un-plugged and re-plugged and reset and tried dozens of times to reprogram via USB and failed. I was so bummed and thought I had major issues. I suspected the boot loader but was unclear hwo it got hosed simply from having a load on Pin 13 while loading a new program, but I built the Parallel port programmer as suggested in post above and re-burned bootloader using Arduino V11 and all was fine right after that. USB programming is great again. I will refrane from having Pin 13 hooked up (and Pin 0 & 1 as well) when uploading software as these are used during the burn process.
