Programming problem need HELP
Hi can anyone help with this sketch, it is supposed to read ground speed radar, and shaft rpm with a reed switch, and control a servo to best match shaft speed to ground speed. i can get the inputs reading well by themselves in separate sketches but when i try to combine them they don’t read at all, im guessing its a problem with the way i’m asking the arduino to follow my programming, please have a look and any help would be appreciated
#include <Servo.h>
int kmph = 0;
int sharftHz = 0;
int sharftRpm =0;
int requiredSharftRpm = 0;
const int frqPin = 5; //Input Pin
const int oneSecond = 100; //Meassured time
const int sharftHallsenserPin = 2; //Input Pin
Servo myservo;
int frqPinState = LOW;
int frq = 0;
int prevFrqPinState = LOW;
unsigned long timerA = 0;
int sharftHallsenserState = LOW;
int prevsharftHallsenserState = LOW;
int pos = 15;
int val; // variable to read the value from the analog pin
unsigned long timerB = 0;
{Serial.begin(9600);
pinMode(frqPin, INPUT); //Declared Pin 5 as Input
pinMode(sharftHallsenserPin, INPUT); //Declared Pin 2 as Input
myservo.attach(9);
pinMode(13, OUTPUT);}
{ //program
{//flash red LED
digitalWrite(13, HIGH);
delay(300);
digitalWrite(13,LOW);
//ground radar frequency to km/h
{ frqPinState = digitalRead(frqPin); //Reads State of Input Pin
if (frqPinState == LOW) //Creates a previos state
{prevFrqPinState = LOW;}
if (frqPinState == HIGH && prevFrqPinState == LOW) //Pulses Counter
{prevFrqPinState = frqPinState;
frq++;}
if (millis() - timerA > oneSecond) //Time Counter
{timerA = millis(); //Resets Time
frq = 0; //Resets Frequency
Serial.print("Ground Speed Frq: ");
Serial.println(frq); //Prints Frequency
kmph = ((frq / 15.6)+0);
Serial.print("Km/h: ");
Serial.println(kmph);}
delay(100);
//Calulate sharft Frequency to rpm
{sharftHallsenserState = digitalRead(sharftHallsenserPin);
if (sharftHallsenserState ==LOW)
{prevsharftHallsenserState = LOW;}
if (sharftHallsenserState == HIGH && prevsharftHallsenserState == LOW) //Pulses Counter
{prevsharftHallsenserState = sharftHallsenserState;
sharftHz++;}
if (millis() - timerB > oneSecond) //Time Counter
{timerB = millis(); //Resets Time
sharftHz = 0; //Resets Frequency
Serial.print("Sharft Hz: ");
Serial.println(sharftHz);}
sharftRpm = (sharftHz * 60 / 4);
Serial.print("Sharft Rpm: ");
Serial.println(sharftRpm);
delay(100);
//calculate required sharft speed and send adjustment to servo
{requiredSharftRpm = kmph * 12.45;
Serial.print("Required Sharft Speed: ");
Serial.println(requiredSharftRpm);
if (sharftRpm > requiredSharftRpm)
{ pos = pos - 2;
pos = max(pos, 2); // assigns pos to the larger of pos or 2
myservo.write(pos); // tell servo to go to position in variable ‘pos’
Serial.print("Servo Location: ");
Serial.println(pos);
delay(15); // waits 15ms for the servo to reach the position
{ Serial.print("No Gain: ");
if (sharftRpm < requiredSharftRpm)
{ pos = pos + 2;
pos = min(pos,179);
{ Serial.print("No Drop: ");
Serial.print("End Of A Cycle: ");
delay(100);
  1. Post your code in code tags,
  2. Auto format your code BEFORE posting it,
  3. At least get to compile before ask us why it's not working
  4. GET RID OF THE DELAY
Mark
Code compiles OK on IDE 1.6.4
#include <Servo.h>
int kmph = 0;
int sharftHz = 0;
int sharftRpm =0;
Servo myservo;
int frq = 0;
int pos = 15;
myservo.attach(9);
{ //program
{//flash red LED
delay(300);
    frq++;}
 delay(100);
  sharftHz++;}
  delay(100);
   { pos = pos - 2;
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    { pos = pos + 2;
    pos = min(pos,179);
delay(100);
Sketch uses 6,170 bytes (20%) of program storage space. Maximum is 30,720 bytes.
Global variables use 395 bytes (19%) of dynamic memory, leaving 1,653 bytes for local variables. Maximum is 2,048 bytes.
Please describe what your code does (or doesn’t do).
;) well hidden, most readers would believe the value of oneSecond in millis() were 1000...
Concatenating different loop constructs (without even removing the output moderating delays) is obviously not the correct approach to combine them.
Whandall: const int oneSecond = 100; //Meassured time
Also, the name is opaque. Conversion constants should be explicit, as in MILLISECONDS_PER_SECOND.
Time was 700 in original sketch just don't know how you put two or more codes together properly
lancegaskell:
#include <Servo.h>
#define DEBUG
int kmph = 0;
int sharftHz = 0;
int sharftRpm =0;
Servo myservo;
int frq = 0;
int pos = 15;
myservo.attach(9);
{ //program
{//flash red LED
delay(300);
#ifdef DEBUG
frqPinState = 0; // initialize / force to low
#endif
frq++;}
delay(100);
sharftHz++;}
delay(100);
{ pos = pos - 2;
{ pos = pos + 2;
pos = min(pos,179);
delay(100);
Suggestion
you can beautify your code as suggested
But at this point it is irrelevant to the app function that 1 second != 100 ms or you are using delay.
Let’s get down to the business and troubleshoot.
You code actually has nice blocks which makes it very easy to identify particular functionality , no matter what it does. ( To the nosy - it checks high and low and time duh!)
So, modify the frqPinState block as follows and run it.
You should add more Serial.print to make sure the variables and the code flow is doing what is expected.
If you keep enclosing them in #ifdef DEBUG … #endif code it is easy to get rid of them when you are done.
“Rinse and repeat” ( goto TestLabel;) the test with setting the frqPinState to high ( figure out how for extra credit) , adjusting /shortening the timerA etc.
Of course you cannot run the test with all the options same time. The test must be logical or it is going to be a mess. Use delay to slow down the Serial prints to manageable / visible output.
Than do same with next functional block…
#define DEBUG
#ifdef DEBUG
TestLabel: frqPinState = 0;       // test force pin state to low, loop back here after delay etc..
#endif
      prevFrqPinState = LOW; // this is pretty clear - no need to check
     // this block should be bypassed - is it ???
      frq++;
   // some test delay here on next go aroudn
    // did it get bypassed on first try ?
      kmph = ((frq / 15.6) + 0);
    delay(100);
#ifdef DEBUG
   // put delay of more than 1 s here and
   goto TestLabel;
#endif
  #ifdef DEBUG
  Serial.println("frqPinState block test DONE ); //Prints Frequency
  for(;;);       // stop and analyze - did it work as excpected?
  #endif
