programming problem
This my code:
Arduino: 1.6.7 (Windows 7), Board: “Arduino/Genuino Uno”
sketch_oct01a:1: error: found ‘:’ in nested-name-specifier, expected ‘::’
Objective : make a one way traffic light */
sketch_oct01a:1: error: ‘Objective’ does not name a type
C:\Users\Edu.Robot.Stem\Desktop\sketch_oct01a\sketch_oct01a.ino: In function ‘void setup()’:
sketch_oct01a:9: error: ‘green’ was not declared in this scope
pinMode(green, OUTPUT);
C:\Users\Edu.Robot.Stem\Desktop\sketch_oct01a\sketch_oct01a.ino: In function ‘void loop()’:
sketch_oct01a:23: error: ‘green’ was not declared in this scope
digitalWrite(green, HIGH);
exit status 1
“Show verbose output during compilation”
enabled in File > Preferences.
Looks like you probably left some stuff at the top of your code that was supposed to be a comment. Since the code didn't get posted it's just a guess though.
It would help if you would post your entire sketch. Use the IDE autoformat function (CTRL-T on a PC), and use code tags which may look like </> on the toolbar.
Until you post your code, my answer is guesswork, but it appears that you left out /* at the beginning of the comment so the comment was taken as incorrect code.
