Hello! I am 12 years old and just now learning how to code Arduino for a class I am taking. I am trying to make it so that when I push the button the code will begin to run. I'm trying to make the Servo move for 30 seconds, then the code changes for 15 seconds, then back to the beginning code for another 30 seconds with a single push of the button. I am trying to make the button start the code. When I press button 1 I would like the Servo to sweep from 0 to 60 quickly. Once it finishes that I would like it to sweep from 0 to 60 at a different speed. My Servo Control wire is on pin 3. Can anyone point me in the right direction? I am very new to the Arduino coding.
This is the base code I am trying to edit to make this happen:
/* Sweep
by BARRAGAN <http://barraganstudio.com>
This example code is in the public domain.
modified 8 Nov 2013
by Scott Fitzgerald
http://www.arduino.cc/en/Tutorial/Sweep
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
Please follow the advice given in the link below when posting code. Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
