Programming Quectel M95 by Arduino- Connection and Command issue
Hello Everybody,
I was trying to connect the Arduino UNO board with the GSM2Click board that has an Quectel M95 module embedded on.
Vcc=5V already set by the switch correctly.
I’ve made the following connection:
ARDUINO pin | GSM pin:
10 RX
11 TX
8 STA
7 PWK (always high)
The gsm2click board seems to be active because both the switch power and network are on (net led is blinking).
After do this I put the PWK=1 and wrote the following sketch:
#include <SoftwareSerial.h>
const int PWK= 7; // Analog output pin that the LED is attached to
const int STA= 8;
const int RX= 10;
const int TX= 11;
int STA_value;
//AT+IPR=9600 , poi dopo aver ricevuto ok mando anche AT&W, per il check mando AT+IPR?
SoftwareSerial mySerial(RX,TX); // RX, TX
void gsmOn() {
  // Takes 30 seconds to complete
  digitalWrite(PWK, HIGH);   // turn the Phone on
  // initialize the digital pin as an output.
  pinMode(PWK, OUTPUT);   // questo pin serve per accendere il dispositivo GSM
  pinMode(STA, INPUT);
  pinMode(RX,INPUT);
  pinMode(TX,OUTPUT);
  gsmOn();
  Serial.begin(9600);  //Init seriale sw
  delay(10);
  mySerial.begin(9600);  //init seriale hw
  delay(100);
      sendCommand("AT");
        readSerial();
void sendCommand(char* msg)
  mySerial.println(msg);
void readSerial()
  if (mySerial.available()>0)
    //Serial.println("reading..");
    Serial.println(mySerial.read());
    delay(10);
  }else
  Serial.println("serial not available");
When I check the answer from the serial monitor I always get “0” after the AT and not OK.
What I’m missing ? Could anyone help?
Thanks a lot.
Marco
