Hello all,
I am a bit of a newby, especially with this programming language. I can accomplish what I want but I want it a little bit smarter and I hope you can direct me to an example that does exactly that, one that is understandable for me.
I used the code below from an example, I have leds on my guitar and now I want guitar scales to light up. In the code below I have few key's but this way I have to define every led separately.
Basically there is a system in this, suppose I declare the key of C somewhere and then I add 8 to the index each time (because thats how I made the leds, 8 per fret and I waist the 2 latest pins of the shift register so I don't have to think about that now)
So can I store the key of C, add 8 to the index and show it (it will be the key of C#) and then use the same key of C and add 16 (it will be the key of D) then add 24 and it will be the key of D#
By the time I get to the 12th fret all will repeat so from there I can automise the whole thing right? or is this too complicated..
Suppose I make an array of the key of C, then how do store it and add 8 using the approach below?
Thanks!!
int SER_Pin = 8; //pin 14 on the 75HC595
int RCLK_Pin = 9; //pin 12 on the 75HC595
int SRCLK_Pin = 10; //pin 11 on the 75HC595
//How many of the shift registers - change this
#define number_of_74hc595s 4
//do not touch
#define numOfRegisterPins number_of_74hc595s * 8
boolean registers[numOfRegisterPins];
void setup(){
pinMode(SER_Pin, OUTPUT);
pinMode(RCLK_Pin, OUTPUT);
pinMode(SRCLK_Pin, OUTPUT);
//reset all register pins
clearRegisters();
writeRegisters();
//set all register pins to LOW
void clearRegisters(){
for(int i = numOfRegisterPins - 1; i >= 0; i--){
registers[i] = LOW;
//Set and display registers
//Only call AFTER all values are set how you would like (slow otherwise)
void writeRegisters(){
digitalWrite(RCLK_Pin, LOW);
digitalWrite(SRCLK_Pin, LOW);
int val = registers[i];
digitalWrite(SER_Pin, val);
digitalWrite(SRCLK_Pin, HIGH);
digitalWrite(RCLK_Pin, HIGH);
//set an individual pin HIGH or LOW
void setRegisterPin(int index, int value){
registers[index] = value;
void loop(){
setRegisterPin(1, HIGH); // this is the key of C!
setRegisterPin(5, HIGH);
setRegisterPin(6, HIGH);
setRegisterPin(10, HIGH);
setRegisterPin(11, HIGH);
setRegisterPin(12, HIGH);
setRegisterPin(17, HIGH);
setRegisterPin(18, HIGH);
setRegisterPin(19, HIGH);
setRegisterPin(21, HIGH);
setRegisterPin(22, HIGH);
setRegisterPin(28, HIGH);
//setRegisterPin(2, LOW);
//setRegisterPin(10, LOW);
writeRegisters();
delay(2000);
clearRegisters();
setRegisterPin(1, HIGH); //C#
setRegisterPin(2, HIGH);
setRegisterPin(3, HIGH);
setRegisterPin(4, HIGH);
setRegisterPin(9, HIGH);
setRegisterPin(13, HIGH);
setRegisterPin(14, HIGH);
setRegisterPin(20, HIGH);
setRegisterPin(25, HIGH);
setRegisterPin(26, HIGH);
setRegisterPin(27, HIGH);
setRegisterPin(29, HIGH);
setRegisterPin(30, HIGH);
writeRegisters();
delay(2000);
clearRegisters();
setRegisterPin(9, HIGH); //D
writeRegisters();
delay(2000);
clearRegisters();
setRegisterPin(1, HIGH); //D#
writeRegisters();
delay(2000);
clearRegisters();
