programming question on loop
how can i make this code work by the push of the button only from 90 degrees button/contact is press and when the button is pressed the degrees go back to 0.
  buttonState = digitalRead(buttonPin);   // read the state of the pushbutton value:
  if (buttonState == HIGH);               // check if the pushbutton is pressed.
                                          // if it is, the buttonState is HIGH
  myservo.write(pos);                     // tell servo to go to position in variable 'pos'
  pos = 90;                               // goes from 90 degrees to 0 degrees
  delay(2500);                            // delay 2.5s for servo to move
  if (buttonState == LOW);                // check if the pushbutton is depressed.
                                          // if it is, the buttonState is LOW
  digitalWrite(ledPin, buttonState);      // turn LED on when it gets there
  pos = 0;                                // goes from 0 degrees to 90 degrees
                                          // turn LED off
the good thing about deja vu is you've seen it before!
hahaha thanks AWOL; appreciate a good sarcasim once in a while. lol
yeah i know is that i have so much in my head that i can think of figuring out the second button.
forgot to squeeze in there the part where the second button is pressed to bring the degrees back to "0"
hmm I'm not AWOL I wonder if he is more upset or me
you win no friends by posting the same question multiple times
maybe you should read the replies a little more carefully
You make even fewer friends by not REMOVING THE SEMICOLONS.
PaulS has told you; I've told you - why don't you do it?
AWOL, PaulS;
the fun part is that IF once again IF i remove the simicolons the prograqm wont work,
i mean there is a reason why im asking for the help. here is my last sketch and it works fine for the ecception of that know i need the program to work with a second button as the second trigger "meaning" the second button is the one that send the signal to the servo to go to the next degrees.
im not ignoring you post im trying them as we post and some of them compile and must of them dont. so bare with me.
maybe you should read the replies a little more carefull!
sorry about that.
people would be a lot more inclined to help if you a) read the posts carefully b) did what people suggested c) posted the code that you have changed
the semicolons MUST NOT FFS be there please go over each of the posts and read it until you understand every word people are trying very hard to help you you seem to read one word in three then code something else
signed exasperated of Leighton Buzzard
this is the original that im currently using and the servo works when i press the button and it goes to “0” then to “90” degrees and when i let go it will stop. what i would like for it to do is go up/90 degrees one button and goes down/0 degrees when i push the second button which is not on the code below.
  Button_Sweep
 Turns on and off a light emitting diode(LED) connected to digital
 pin 13, when pressing a pushbutton attached to pin 2.
 The circuit:
 * LED attached from pin 13 to ground
 * pushbutton attached to pin 2 from +5V
 * 10K resistor attached to pin 2 from ground
 * Note: on most Arduinos there is already an LED on the board
 attached to pin 13.
  #include <Servo.h>
  Servo myservo;                          // create servo object to control a servo
                                          // a maximum of eight servo objects can be created
                                          // constants won't change. They're used here to
                                          // set pin numbers:
  int ledPin =  10;                       // the number of the LED pin
  int buttonPin = 2;                      // the number of the pushbutton pin
  int pos = 0;                            // variable to store the servo position
  int buttonState = 0;                    // variable for reading the pushbutton status
  pinMode(ledPin, OUTPUT);                // initialize the LED pin as an output:
  pinMode(buttonPin, INPUT);              // initialize the pushbutton pin as an input:
  myservo.attach(9);                      // attaches the servo on pin 9 to the servo object
  delay(5500);                            // delay 5.5s for servo to move
  delay(500);                            // delay 5/100th of a second for servo to move
                                          // turn LED off
DOES NOTHING BECAUSE THAT’S WHAT YOU TOLD IT TO DO
signed
the semicolons as you guys are requesting are giving troubleshooting when i remove them thats why i cont to post the codes the way they are.
sorry for any of your inconveniences......
I will try one more time
REMOVE THE GODDAM semicolons
then look at your code
the structure of an IF statement is
IF ( <> )
do this
when you write IF (<>);
you are saying test the condition then do nothing
the IF stops when it hits the semicolon
so remove the semi colon and put all the things you want to do inside {…}
it will compile
it will work
ignoring us won’t work!
(well it will eventually because we will ignore you!)
ok ppl
hoo blooming ray
now did you read the rest of the post?
I hate to be picky*, but that sentence speaks volumes; programming is about precision and attention to detail.
If you’re not willing to embrace those concepts, give up now - it will save us all a great deal of time.
*I lied - I love to be picky; it pays the bills
hee hee!
It isn't funny. :0
I propose that Arduino C (or all C) be changed from tomorrow onwards to not require semicolons. In fact, I’d go so far as to say that Arduino C should be changed to Arduino Ruby. Then I’d be happy.
[quote author=Ian Tindale link=topic=65750.msg481942#msg481942 date=1309939824] I propose that Arduino C (or all C) be changed from tomorrow onwards to not require semicolons. In fact, I’d go so far as to say that Arduino C should be changed to Arduino Ruby. Then I’d be happy. [/quote] Excellent idea. Now all you have to do is write a compiler that generates AVR machine code from Ruby. Then lots of people will be happy.
While you're at it, could you throw in a Python compiler for me? Ta.
