Hello everyone -
My son and I are trying to run a 4 motor rover with the Arduino Duemilanove and the AdaFruit motor shield, with input from the Parallax Ping sensor. The motors work well and respond properly to the Motor Runner sketch provided by Adafruit, and the Ping operates properly with the Ping sample sketch. I am trying to get the rover to move forward until an obstacle of x distance is in front of it, and then stop. When I mix the two sketches (as attached), the PING works properly, but the motors REFUSE to move as long as the motor.run commands are within the if/else loop. I know that the if/else loop is working properly because the Serial Monitor returns the correct “Stopped” or “Go, go, go!” messages, dependent on the distance read by PING. If I move the motor.run command to immediately after the void loop command, it works, but nowhere else. What am I missing here? Any assistance would be great.
#include <AFMotor.h>
const int pingPin = 7;
const int threshold = 1000; // threshold of distance in miliseconds
AF_DCMotor motor1(1, MOTOR12_1KHZ); // create motor #1, 64KHz pwm
AF_DCMotor motor2(2, MOTOR12_1KHZ); // create motor #2, 64KHz pwm
AF_DCMotor motor3(3, MOTOR12_1KHZ); // create motor #3, 64KHz pwm
AF_DCMotor motor4(4, MOTOR12_1KHZ); // create motor #4, 64KHz pwm
Serial.begin (115200);
motor1.setSpeed(255); // set the speed to 150/255
motor2.setSpeed(255); // set the speed to 150/255
motor3.setSpeed(255); // set the speed to 150/255
motor4.setSpeed(255); // set the speed to 150/255
void loop () {
long duration, inches, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(5);
digitalWrite(pingPin, HIGH);
pinMode (pingPin, INPUT);
duration = pulseIn (pingPin, HIGH);
Serial.print(duration);
if (duration < threshold) { //if the distance is less than 1000 miliseconds (approximately 6 inches), stop the motors
motor1.run(RELEASE); // stopped
motor2.run(RELEASE); // stopped
motor3.run(RELEASE); // stopped
motor4.run(RELEASE); // stopped
Serial.print("Stopped");
delay (1000);
else { //if the distance is greater than 1000 miliseconds or approximately 6 inches, move forward 6 inches.
motor1.run(FORWARD); // turn it on going forward
motor2.run(FORWARD); // turn it on going forward
motor3.run(FORWARD); // turn it on going forward
motor4.run(FORWARD); // turn it on going forward
Serial.print("Go, go, go!");
Ping_and_Motors.ino (1.61 KB)
