Programming question to determine a mean value @ Arduino Due
Hi there
Im trying to use AnalogRead to get voltage data from a seonsr. It works so far. I wanted to determine a mean value of x measuremnts to increase the accuracy. But when I see my results throught Printline I figure out the my result increases all the time. SO my question is is my code wrong or write ?
It is just a few lines to calculate the mean value !!
Thanks in advance
const int numReadings = 100;// how many measurments shall be calculated to the mean value calculation
float readings[numReadings];      // the readings from the analog input
int readIndex = 0;              // the index of the current reading
float total = 0;                  // the running total
float average = 0;                // the average
int Sensor_1 = A0;// Sensor 1
float Offset_Voltage_Sensor_1= 1.635; // Offset Voltage of the sensor must be removed -1.635 to get 0 volt
float volt= 3.300000/1024.000; // 3.3 Volt from Arduino DUE / 2^10 bit for 10 bits resolution
  // initialize all the readings to 0:
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
  analogReadResolution(10); // Max @ DUE 12 Bit
  // subtract the last reading:
  total = total - readings[readIndex];
  // read from the sensor:
  readings[readIndex] = (analogRead(Sensor_1)*0.003223-Offset_Voltage_Sensor_1);
  // add the reading to the total:
  total = total + readings[readIndex];
  // advance to the next position in the array:
  readIndex = readIndex + 1;
  // if we're at the end of the array...
  if (readIndex >= numReadings)
    // ...wrap around to the beginning:
    readIndex = 0;
  // calculate the average:
  average = total / numReadings;
  Serial.print(" Voltage Sensor 1 : ");
  Serial.println(                    average,4);
 delay(100);        // delay in between reads for stability
Hello DUEDUE,
You never Zeroed your total after the averaging. Also, it should be better if you use a 'for loop' instead of if>= and ++.
Here your corrected code:
  for (readIndex = 0; readIndex < numReadings; readIndex++)
    readings[readIndex] = 0;
  readIndex = 0;
  total = 0;
Here a code with using 'for loop':
  for(readIndex=0; readIndex<numReadings;readIndex++)
  total = 0;
Regards,
p
