Hi guys,
I am having trouble translating this sentence 'To sequentially read each sensor, connect your triggering device to pin 4 (RX) of the first sensor, then connect pin 5 (TX) output of the first sensor to the RX pin of the next sensor that is to be ranged in sequence. Do this with however many sensors are to be used in the chain. ' into a code. Does any of you guys know how to do it?
Here is the datasheet and is on page 4
Can anybody help me out?
This is my current code
const int anPin1 = 0;
const int anPin2 = 1;
const int anPin3 = 2;
const int anPin4 = 3;
int triggerPin1 = 13;
long distance1, distance2, distance3, distance4;
Serial.begin(9600); // sets the serial port to 9600
pinMode(triggerPin1, OUTPUT);
void start_sensor(){
digitalWrite(triggerPin1,HIGH);
delay(1);
digitalWrite(triggerPin1,LOW);
void read_sensors(){
Scale factor is (Vcc/512) per inch. A 5V supply yields ~9.8mV/in
Arduino analog pin goes from 0 to 1024, so the value has to be divided by 2 to get the actual inches
distance1 = analogRead(anPin1)/2;
distance2 = analogRead(anPin2)/2;
distance3 = analogRead(anPin3)/2;
distance4 = analogRead(anPin4)/2;
void print_all(){
Serial.print("S1");
Serial.print(" ");
Serial.print(distance1);
Serial.print("in");
Serial.print(" ");
Serial.print(" ");
Serial.print("S2");
Serial.print(" ");
Serial.print(distance2);
Serial.print("in");
Serial.print(" ");
Serial.print(" ");
Serial.print("S3");
Serial.print(" ");
Serial.print(distance3);
Serial.print("in");
Serial.print(" ");
Serial.print(" ");
Serial.print("S4");
Serial.print(" ");
Serial.print(distance4);
Serial.print("in");
start_sensor();
read_sensors();
print_all();
delay(200); //This is the equivant of the amount of sensors times 50. If you changed this to 5 sensors the delay would be 250.
