Programming Question
I have this robot that when I put the last code to make it move it goes in circles instead of going straight.
Here’s the Code:
    L = Left
    R = Right
    F = forward
    B = backward
#include <Servo.h>
int pinLB = 12;     // define pin 12
int pinLF = 3;     // define pin 3
int pinRB = 13;    // define pin 13
int pinRF = 11;    // define pin 11
int inputPin = 4;    // define pin for sensor echo
int outputPin =5;    // define pin for sensor trig
int Fspeedd = 0;      // forward speed
int Rspeedd = 0;      // right speed
int Lspeedd = 0;      // left speed
int directionn = 0;   // forward=8 backward=2 left=4 right=6
Servo myservo;        // set myservo
int delay_time = 250; // settling time after steering servo motor moving B
int Fgo = 8;         // Move F
int Rgo = 6;         // move to the R
int Lgo = 4;         // move to the L
int Bgo = 2;         // move B
  Serial.begin(9600);     // Define motor output pin
  pinMode(pinLB,OUTPUT); // pin 12
  pinMode(pinLF,OUTPUT); // pin 3 (PWM)
  pinMode(pinRB,OUTPUT); // pin 13
  pinMode(pinRF,OUTPUT); // pin 11 (PWM)
  pinMode(inputPin, INPUT);    // define input pin for sensor
  pinMode(outputPin, OUTPUT);  // define output pin for sensor
  myservo.attach(9);    // Define servo motor output pin to D9 (PWM)
void advance()     // move forward
    digitalWrite(pinLB,LOW);    // right wheel moves forward
digitalWrite(pinRB, LOW);  // left wheel moves forward
    analogWrite(pinLF,255);
    analogWrite(pinRF,255);
void stopp()         // stop
     digitalWrite(pinLB,HIGH);
     digitalWrite(pinRB,HIGH);
     analogWrite(pinLF,0);
     analogWrite(pinRF,0);
void right()        // turn right (single wheel)
   digitalWrite(pinLB,HIGH);  // wheel on the left moves forward
   digitalWrite(pinRB,LOW); // wheel on the right moves backward
   analogWrite(pinLF, 255);
void left()         // turn left (single wheel)
   digitalWrite(pinLB,LOW);  // wheel on the left moves backward
   digitalWrite(pinRB,HIGH); // wheel on the right moves forward
void back()          // move backward
     digitalWrite(pinLB,HIGH);  // motor moves to left rear
     digitalWrite(pinRB,HIGH);  // motor moves to right rear
void detection()        // measure 3 angles (0.90.179)
      int delay_time = 250;   // stabilizing time for servo motor after moving backward
      ask_pin_F();            // read the distance ahead
     if(Fspeedd < 10)         // if distance ahead is <10cm
      stopp();               // clear data
      delay(100);
      back();                // move backward for 0.2S
      delay(200);
      if(Fspeedd < 25)         // if distance ahead is <25cm
        stopp();
        delay(100);             // clear data
        ask_pin_L();            // read distance on the left
        delay(delay_time);      // stabilizing time for servo motor
        ask_pin_R();            // read distance on the right
        if(Lspeedd > Rspeedd)   // if distance on the left is >distance on the right
          directionn = Lgo;      // move to the L
         if(Lspeedd <= Rspeedd)   // if distance on the left is <= distance on the right
         directionn = Rgo;      // move to the right
        if (Lspeedd < 10 && Rspeedd < 10)   // if distance on left and right are both <10cm
         directionn = Bgo;      // move backward
      else                      // if distance ahead is >25cm
        directionn = Fgo;        // move forward
void ask_pin_F()   // measure the distance ahead
      myservo.write(90);
      digitalWrite(outputPin, LOW);   // ultrasonic sensor transmit low level signal 2μs
      delayMicroseconds(2);
      digitalWrite(outputPin, HIGH);  // ultrasonic sensor transmit high level signal10μs, at least 10μs
      delayMicroseconds(10);
      digitalWrite(outputPin, LOW);    // keep transmitting low level signal
      float Fdistance = pulseIn(inputPin, HIGH);  // read the time in between
      Fdistance= Fdistance/5.8/10;       // convert time into distance (unit: cm)
      Fspeedd = Fdistance;              // read the distance into Fspeedd
  Serial.print("Fspeedd = ");
  Serial.print(Fspeedd );
  Serial.println("  cm");
 void ask_pin_L()   // measure distance on the left
      myservo.write(5);
      delay(delay_time);
      float Ldistance = pulseIn(inputPin, HIGH);  // read the time in between
      Ldistance= Ldistance/5.8/10;       // convert time into distance (unit: cm)
      Lspeedd = Ldistance;              // read the distance into Lspeedd
  Serial.print("Lspeedd = ");
  Serial.print(Lspeedd );
      Serial.print("  cm  ");
void ask_pin_R()   //  measure distance on the right
      myservo.write(177);
      delay(delay_time);
      float Rdistance = pulseIn(inputPin, HIGH);  // read the time in between
      Rdistance= Rdistance/5.8/10;       // convert time into distance (unit: cm)
      Rspeedd = Rdistance;              // read the distance into Rspeedd
  Serial.print(" Rspeedd = ");
  Serial.print(Rspeedd );
    myservo.write(90);  // home set the servo motor, ready for next measurement
    detection();        // measure the angle and determine which direction to move
   if(directionn == 2)  // if directionn= 2
     back();
     delay(800);                    //  go backward
     left() ;
     delay(200);              // Move slightly to the left (to prevent stuck in dead end)
   if(directionn == 6)           // if directionn = 6
   { back();
     delay(100);
     right();
     delay(600);                 // turn right
   if(directionn == 4)          // if directionn = 4
   { back();
     delay(600);
     left();
     delay(600);                  // turn left
   if(directionn == 8)          // if directionn = 8
   { advance();       // move forward
    delay(100);
Is the problem in the code because I’m not sure. At first I thought it was the ultrasonic sensor, but I already fixed that. The robot I have is a Keyestudio Mini Tank Robot. If anyone had ever gotten one of these robots could you help me.
Maybe you wired one motor the other way around?
That is the worst indenting I've seen this month. I went cross-eyed trying to read it. I gave up. The Tools + Auto Format menu item makes it simple to indent properly, if you can't.
Don't post a mess like that again.
Have you written some simple code to make the motors run, this will tell you if you have the motors wired correctly.
Because one motor is turned over it has to run in the opposite direction to its partner to drive the robot in the same direction.
Thanks.. Tom.... :slight_smile:
I have the same bot. The wires to the motor shield when looking at it from the back should be red, black, black, red.
TAColomb:
I hope the OP has solved it somewhere in the last two years :slight_smile:
