Programming Questions / Millis to trigger LED for set time then reset
so Im trying to make a LED turn on for a set interval (1 second) when that function is called. the function will only be called if an IF statement in the main loop is true. I would then like the LED to turn back off after the 5 seconds then "reset" to allow me to call the function again if that same IF statement is true. I have been trying this for a couple days and feel like im missing something basic in my code to allow this.
any tips would be awesome.
int led = 13;
pinMode(led, OUTPUT); // initialize LED output
if (something=something)
timers();
//the led should always be off until the timers() function is called and its only on for the interval time
//the led is turned back off after the time has expired
//timers should "reset" its self, allowing for it to be called again and again regardless of time
void timers() {
unsigned long previousMillis = 0;
const long interval = 1000;
if (currentMillis - previousMillis >= interval){
digitalWrite(led, HIGH); //turns led on for the interval
digitalWrite(led, LOW); //turns back off when the time is greater than the interval
sketch_mar27a.ino (783 Bytes)
