Programming request
Dear All,
I am the new Adriano user and I don’t know how to write the C langauage, I am trying to learn it from Internet.
I want to create a IR remote to control some LEDs, and target :
Press a button number 5 - a led will power on (this part is ok now)
Press a button number 4 - a set of LED will running from left to right (this part is ok now)
Press a button number 9 - i want the 2 LEDs start to blinking, but cannot now, the result is press one times, it bright and stopped, and press again, it will be power off, so I need to non-stop press and press to manual start the blinking.
Press a button number 1 - trun all LEDs off.
Now, I hope some C professional help to teach me how can fix the button 9? I want to press one time, all LEDs will start blinking until press button 1 to trun all off. I really want you help, thank you very much.
Attached my code in below.
#include <IRremote.h> // use the library for IR
const int receiver = 2;            // pin for IR receiver to Arduino digital pin 11
const int Rled01 =  8;
const byte NUM = 5;
const byte Blueled[] = {3, 4, 5, 6, 7};
const int delaytime = 80;
bool Runningledloop = false;
int i;
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results;
boolean lightState1 = false;
unsigned long last1 = millis();
class Flasher
    int ledPin;
    long OnTime;
    long OffTime;
    int ledState;
    unsigned long previousMillis;
  public:
    Flasher(int pin, long on, long off)
      ledPin = pin;
      pinMode(ledPin, OUTPUT);
      OnTime = on;
      OffTime = off;
      ledState = LOW;
      previousMillis = 0;
    void Update()
      if ((ledState == HIGH) && (currentMillis - previousMillis >= OnTime))
        ledState = LOW;
        digitalWrite(ledPin, ledState);
      else if ((ledState == LOW) && (currentMillis - previousMillis >= OffTime))
        ledState = HIGH;  // turn it on
Flasher led1(9, 123, 400);
Flasher led2(10, 350, 350);
  pinMode(Rled01, OUTPUT);
  irrecv.enableIRIn();
  for (i = 0; i < NUM; i++)
    pinMode(Blueled[i], OUTPUT);
    digitalWrite(Blueled[i], LOW);
  if (Runningledloop)
    if (i > NUM - 1 ) i = 0;
    digitalWrite(Blueled[i], HIGH);
    delay(delaytime);
    i++;
  if (irrecv.decode(&results))
    if (results.value == 0xC1AA827D) // || 0xFF6897) // remote button 5
      if (millis() - last1 > 300)
        lightState1 = !lightState1;
        digitalWrite(Rled01, lightState1);
        last1 = millis();
    if (results.value == 0xC1AAF10E) // || 0xFF18E7)  remote button 9
    led1.Update();
    led2.Update();
    if (results.value == 0xC1AAC23D) // ||0xFF7A85)  remote button 4
      Runningledloop = true;
    if (results.value == 0xC1AAFC03) //remote button 1  || 0xFF02FD
      digitalWrite(Rled01, LOW);
    irrecv.resume();
you need to introduce a new global variable, so the code becomes something like:
bool flashingLEDS = false;
loop()
    if (flashingLEDS)
        led1.Update();
        led2.Update();
    if (decodeIR)
          flashingLEDS = true;
don't forget to set flashingLEDS = false when you press other buttons.
Simplify your program to see what is happening. Do you know that “9” is being received? Do you know that it is entering the flash part of your program?
You can send comments to the serial terminal. EG, "9 detected ", “in flash routine” etc. this will confirm the program is getting to a particular point.
Weedpharma
weedpharma:
Simplify your program to see what is happening. Do you know that "9" is being received? Do you know that it is entering the flash part of your program?
You can send comments to the serial terminal. EG, "9 detected ", "in flash routine" etc. this will confirm the program is getting to a particular point.
Weedpharma
Dear weedpharma
I never try in serial terminal, let me open it to try but not sure what can I do, let me think first, thanks
arduinodlb:
loop()
    if (flashingLEDS)
        led1.Update();
        led2.Update();
    if (decodeIR)
Dear, thanks for your recommendation, let me Change my code to see what is result first
