→ German Thread: http://forum.arduino.cc/index.php?topic=573174.msg3904018#msg3904018
Hey ho folks!
I’m completely new to Arduino and I could need help in programming an “Oscilloscopy-thing”
OK first: I’m electrical engineer and have no big programming skills, so I won’t be able to write it on my own (I wouldn’t ask for it).
I’m building a analog synthesizer right now and wanted to give a small “cherry” on top by adding kinda like an oscilloscope to it.
But nothing of the internets programm codes fits to the purpose.
To explain my problem:
I wanted to visualize the signal of the main output as a gimmick to the build. That means to show the scratched triangle, square, saw waves to have a imagination to the signals.
That means that the shown signal MUST be the same level and the same frequency (getting normalized) all the time when I’m playing the different notes. I don’t know if this is possible to do without further hardware. I don’t need to see any frequencies so the time-area is enough for that small purpose.
Another cool thing would be to have a start screen where it displays some seconds the name of the synth and then starting the signal analyzer.
I got a code that I found somewhere deep on the internet, but I can’t find it again to write the developer. Maybe some of you geeky professionals (or semis :D) could rewrite/ improve the code to my needs. I would be so glad to show this on other community boards (rights to the developer).
As a refer I posting this link to a Dreadbox Medusa Synth. You can see that the screen on the right sometimes shows of the signal, no matter which note you’re playing A Smooth Sequence on Medusa Synthesizer - YouTube
#define FILENAME "TFTGraph3"
#include <TFT.h> // Arduino LCD library
#include <SPI.h>
// pin definition for the Uno
#define cs 10
#define dc 9
#define rst 8
#define quiet false
TFT TFTscreen = TFT(cs, dc, rst);
byte h = TFTscreen.height();
byte w = TFTscreen.width();
byte b[160];
boolean f = false;
int dt; // microseconds
Serial.println(FILENAME);
Serial.println(w);
Serial.println(h);
ADCSRA = 132; // set prescale to 16, see http://www.microsmart.co.za/technical/2014/03/01/advanced-arduino-adc/
// initialize the display
TFTscreen.begin();
for (int i = 0; i < w; i++) b[i] = -1; // avoid erasing on the first go
// clear the screen with a pretty color
clearScreen();
//==========================================================================00
int a[160]; // "double buffering"
const byte sensorPin = A0;
long t1, t2;
t1 = micros();
// sampling:
for (int i = 1; i < w-1; i++) {
a[i] = analogRead(sensorPin);
// delay if desired
t2 = micros();
dt = t2 - t1;
Serial.println(dt);
// displaying:
if (f) {
TFTscreen.stroke(0, 0, 0); // erase old
TFTscreen.point (i, b[i]);
b[i] = map (a[i], 0, 1023, h-2, 1);
// zero should be at the bottom, 5 volts at the top
TFTscreen.stroke(255, 200, 0); // print new
else {
f = !f;
grid();
// trigger:
/* edge triggered: */
int v1 = analogRead(sensorPin);
int v2 = analogRead(sensorPin);
// wait for rising edge:
while (v2 - v1 < 2) {
v1 = v2;
// wait for falling edge
while (v1 - v2 < 2) {
v1 = v2;
/* alternative use level triggering:
while (analogRead(sensorPin) > 512);
while (analogRead(sensorPin) < 512);
void clearScreen() {
TFTscreen.background(0, 0, 0);
TFTscreen.stroke(255, 0, 0);
TFTscreen.rect(0, 0, w, h);
void grid() { // dotted vertical lines
// display the axes:
TFTscreen.stroke(255, 0, 0); // red
// horizontal lines:
for (int i = 1; i < 5; i++) {
int b = 6;
int x = 3;
while (x < w) {
TFTscreen.line(x, i*h/5, x + b, i*h/5);
x = x + 2 * b;
// vertical lins:
long div = 500; // microseconds
int dx = div * (w - 2) / dt;
int x = 0;
while (x < w) {
int b = 6;
x = x + dx;
int y = 2;
while (y < h) {
TFTscreen.line(x, y, x, y + b);
y = y + 2 * b;
// print margins:
byte h1 = 3*h/5;
TFTscreen.stroke(0,0,0); // background color
TFTscreen.fill(0,0,0);
TFTscreen.rect(w-30,h1-8,29,7);
/*TFTscreen.stroke(255,255,255); // white
TFTscreen.text("0", 1, h1-8);
TFTscreen.text("0.5 ms", w-36, h1-8);
TFTscreen.text("/div", w-24, h1+1);
TFTscreen.text("0V", 1, h-8);
TFTscreen.text("5V", 1, 1);*/
P.S. I will mention the help of the helper in boards
Greetings Avid
