Hi all
I do hope I am allowed to do this as I would like to give something back to the forum for the help I have received so far from you great folks.
It will hopefully help those who like me are just starting out with the Arduino and the coding that goes with it.
It is a small pcb I made to take the ATTiny chips and plug onto the Arduino UNO, also after a lot of trial and error, the instructions to dump your sketch code onto it. You will however need to watch the shrinkify tutorial on youtube. How-To: Shrinkify Your Arduino Projects - YouTube
as you will need ATtiny files.
You will need a piece of strip board, led, ic socket (8 pin), 10uF 25v capacitor, 220ohm resistor and some link wire.
I wont explain where it all goes as the 3 pictures are simple to follow
On this image, the bottom left first pin fits into pin 13 and the bottom right fits into pin reset, all other pins will line up to the correct locations.
The routine I found that works is using the 1.0.4 version of the Arduino software.
Plug the Arduino in, make the board as uno and select the com port for your configuration.
Set the programmer as "AVRISP MKII"
Load the "ArduinoISP" sketch and upload it to the Arduino.
Close the ide software, unplug the Arduino and plug in the board you just made.
plug the Arduino back into the pc and reload the ide.
In the ide tools menu change the board to ATtiny 85 (w/Arduino as ISP)
Load the sketch you want to put on the chip
In the tools menu change the programmer as "Arduino as ISP"
upload your sketch and put:
#include <WProgram.h>
#include <Arduino.h>
at the top of your code
you should see the led on the new pcb flash when it is done.
This has now worked for me 9 times without any problems.
I do however take no responsibility if it goes wrong for you.
Enjoy
Don
