Programming the ATtiny84A without any response
Hi, all
Right now I am using the Arduino Uno to program the ATtiny84A.
But its response is below:
Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\user\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.1.4/avrdude.conf"
         Using Port                    : COM28
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         Setting bit clk period        : 5.0
         AVR Part                      : ATtiny84
         Chip Erase delay              : 15000 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     6     4    0 no        512    4      0  4000  4500 0xff 0xff
           flash         65     6    32    0 yes      8192   64    128  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x000000 (retrying)
Error while burning bootloader.
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
The setup of my Arduino and setting is attached.
I have test the SCK and MOSI is both good. But MISO is not responding.
I don’t know if the library is not fit for ATtiny84A.
Is it only for ATtiny84?
I cannot see the wiring in these images (1.jpg and 2.jpg are the same picture). Most probably you did the wiring wrong.
The ATtiny84A is a slightly newer version of the ATtiny84 with better power saving features.
You don't get a chip signature at all.
