I am currently working on making my Uno control two Electronic speed controllers with two out puts. And I would like to have 60 hz 7.5% duty Cycle to put out on out put 11, 10. I would just like to make it were if a pushbotton is pushed this is what will come out. If it is not pressed then the output will be either nothing or below 6.5% on the duty cycle.
Try the servo library
Rate is a little low, but you could get clues from the source on how to change that
Firstly pins 10 and 11 run from two different timers - pin 11 uses timer2 which is 8 bit and can only go down to 61.03Hz minimum at 16MHz system clock - is that satisfactory?
You might do best to use two pins on the same timer, so pins 9 and 10 (timer1), or pins 11 and 3 (timer2).
You'll have to reset the timer's prescaler value to clock slower than the default, then choose an appropriate mode - for timer1 mode 8 (phase and frequency correct, period set by ICR1) would allow two PWM pins to work.
I think with timer2 there is no way to set a frequency-correct mode and have both PWM pins work, but since you are limited to 61.03Hz, frequency correct is already a lost cause. If 61.03Hz is OK, then you probably just need to change the prescaler bits and use analogWrite() on pins 11 and 3:
Try
void setup ()
pinMode (11, OUTPUT) ;
pinMode (3, OUTPUT) ;
TCCR2A = 0xA3 ;
TCCR2B = 0x07 ;
analogWrite (11, 19) ;
analogWrite (3, 19) ;
and see if the right sort of signal comes out
Thank you for the input. I will get to trying some things and see what happens.
If that shouldn't work:
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
TCCR1A = (1<<WGM11) | (1<<COM1A1) | (1<<COM1B1);
TCCR1B = (1<<WGM12) | (1<<WGM13) | (1<<CS11);
ICR1 = 33333; // (16MHz/8)/60Hz=33333
OCR1A = 2500; // 33333*0,075 = 2500
This should produce 60Hz, 7,5% duty cycle at pin 9 and 10, but this code isn't tested.
I'm using the mode 15 from the datasheet (page 136):
http://www.google.com/url?sa=t&rct=j&q=atmega328p%20datasheet&source=web&cd=1&ved=0CCEQFjAA&url=http%3A%2F%2Fwww.atmel.com%2FImages%2Fdoc8161.pdf&ei=enBYUI6oGY7itQbZ9YG4AQ&usg=AFQjCNFcwQZ1S5ZXKLGwKQ_u54ggN55CkQ&cad=rja
Greetings,
DaDrivel
I have a library that will control four servos at upto 125Hz, what are you using it in and do you know what your doing ?
If so I can send you the library.
Duane B
