Hello, I am building a 8key mechanical keyboard, so I need at this point the usb interface to communicate with the computer, Vcc, GND, D+ and D- with USB protocols. So theorically I know how to do it, but I never did it before. I just programmed I2C protocols and tested, but never USB.
Has arduino something to do this? I mean a library, or something like I2C (well I programmed I2C but I know it has his libraries, etc...). The USB interface and protocols in order to communitace to a USB Host controller. I will need the interrup transfers (usb 1.0 should be enough for 4bit of information I might use).
The ATmega16U2 on the Uno is just a helper chip and that is almost the same as the ATmega32U4 on the Leonardo, but that is the main microcontroller. They have native USB.
With Arduino version 1.6.6 they seem to have changed the way libraries use the USB to make it easier to make it all kind of USB devices.
There is a disadvantage, the Leonardo uses the USB cable to act as a keyboard, but also to upload a sketch and for the serial monitor. That is a whole lot of confusing things together, but it is possible to turn off what you don’t want.
