I'm going to buy a Matebook by Huawei (not macbook). However, I seen that we have only USB-C plug.
But with the computer, Huawei give to you an adapterUSB-C > HDMI, VGA, USB 3.0...
So, is it a problem to use this type of adaptator? Coding is not a problem with this computer? Someone has this computer?
We have seen some occasional problems caused by using Arduino boards on USB 3.0 ports, though I suspect many people are using 3.0 ports with no problems.
The workaround if you do have a problem is to connect a USB 2.0 hub between the USB 3.0 port and the Arduino. That will fix the problems.
