I am doing a project with joystick and I want make it into before you can start moving with joystick you need to move the joystick one round, but I am new to it, so I need some help in it
Sequence
~User need to turn the joystick one full round
If true
~Do something
//UPDATED
int Pin_X_Axis = A0;
int Pin_Y_Axis = A1;
int XAxis = 0;
int YAxis = 0;
const int X_Axis_Min = 0;
const int X_Axis_Max = 1023;
const int Y_Axis_Min = 0;
const int Y_Axis_Max = 1025;
pinMode(Pin_X_Axis,INPUT);
pinMode(Pin_Y_Axis,INPUT);
int XAxis = analogRead(Pin_X_Axis);
int YAxis = analogRead(Pin_Y_Axis);
if ( XAxis == X_Axis_Min && XAxis == X_Axis_Max && YAxis == Y_Axis_Min && YAxis == Y_Axis_Max )// this line is wrong which I need help in
do something
A sequence of steps that have to be followed before being permitted to do the actual work is often called an 'arming sequence'.
I like the idea.
Help me with this.
Something like
move the joystick to the lower left
move the joystick to the upper left
move the joystick to the upper right
move the joystick to the lower right
Not sure to understand what you want, but I think you want the player to put the joystick at the 4 angles before doing something else.
If so, here is what I suggest (not tested) :
int XAxis = 0;
int YAxis = 0;
const int X_Axis_Min = 234;
const int X_Axis_Max = 775;
const int Y_Axis_Min = 255;
const int Y_Axis_Max = 776;
bool TopLeft = false;
bool TopRight = false;
bool BottomLeft = false;
bool BottomRight = false;
pinMode(Pin_X_Axis, INPUT);
pinMode(Pin_Y_Axis, INPUT);
while (!TopLeft && !TopRight && !BottomLeft && !BottomRight) {
if (XAxis <= X_Axis_Min && YAxis <= Y_Axis_Min && !TopLeft) {
TopLeft = true;
Serial.println("Top Left !");
if (XAxis >= X_Axis_Min && YAxis <= Y_Axis_Min && !TopRight) {
TopRight = true;
Serial.println("Top Right !");
if (XAxis <= X_Axis_Min && YAxis >= Y_Axis_Min && !BottomLeft) {
BottomLeft = true;
Serial.println("Bottom Left !");
if (XAxis >= X_Axis_Min && YAxis >= Y_Axis_Min && !BottomRight) {
BottomRight = true;
Serial.println("Bottom Right !");
Serial.println("Finished !");
while (1);
To see the output, set the serial monito to 115200 bauds.
And the labels (Top Left, Bottom right, etc) may be wrong, it's just to show you one way of doing it.
TopLeft = true;
TopRight = true;
BottomLeft = true;
BottomRight = true;
while (1);
Hmm it is not working as what I wanted,what I meant is
1st. User need to turn the joystick one full round
If true
Do something
