But wenn I try to upload something to my board using the programmer, i get an Java error:
java.lang.NullPointerException
at processing.app.debug.AvrdudeUploader.getProgrammerCommands(Unknown Source)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(Unknown Source)
at processing.app.Sketch.upload(Unknown Source)
at processing.app.Sketch.exportApplet(Unknown Source)
at processing.app.Editor$DefaultExportHandler.run(Unknown Source)
at java.lang.Thread.run(Thread.java:619)
To the boards.txt I’ve added this line:
sanguino.upload.using=stk500v2
To programmers.txt I’ve added/edited this:
avrispmkii.name=stk500v2
avrispmkii.communication=serial
avrispmkii.protocol=stk500v2
I don’t see anything wrong here acourding to the manual above…burning the bootloader with the programmer works just fine…
Yes, it does work. However, in this case, I am assuming it uses the USB port and boot loader. I have designed my own board and have the raw Atmel part on it. I am planning to use it for a real commercial product. Therefore, I need to figure out how to make it work without the bootloader. I would rather use the Arduino method instead of re-creating functionality within Atmel AVR environment.
I have no idea what effect preferences.txt / upload.using has. And, given what you've described, I suspect it doesn't work the way you're expecting. I suggest you create an entry in boards.txt for your commercial product and, if necessary, add an entry to programmers.txt for your JTAGICE MKII.
Have you tried using AVRDUDE from the command-line with your JTAGICE MKII?
