i cant program my arduino my code is attatched [ls help
i am new to arduino so pls pls help :o
Complete program.txt (16.4 KB)
"Can't program" means a lot of different things.
What does your program do? What do you want it to do?
yeh as i said i am new to arduino i started going through videos of arduino that is when i got my birthday gift of an arduino kit from banggood 2 weeks i tried to programme but errors
i am making the turtle smart car from banggood i tried programing but errors today i got this error
exit status 1
invalid preprocessing directive #Include
pls give me a headstart on this i am new i will be grateful
Case matters. #include should be spelled with a lower case i
Try this attach
Edit:
To install IRremote Arduino Library
Here you got the manuals in step by step images
Complete program.txt (15.8 KB)
Use the preview button when you post and there you can find the code for posting your sketch to your post. Much easier to get help that way.
new problem
stray '\302' in program
Please give more details on the problem then one liner.
if possible and you have no problem pls compile the uploaded sketch and pls pls correct it and upload :o
Have you try the sketch that I posted?
I have successful compiled.
i mean attatch iwill download and upload first and last time pls i will do on my own next time pls i was not able to download your code
kevinlol:
please spell please and not pls. You're asking professional programmers for help not texting your girlfriend. Use some grammar and punctuation and act like you have a little bit of maturity and education. Please give us at least that much respect if you want us to do anything for you.
I am so sorry .
When I look at your code it appears that most of your comments are written with a space between the two slashes. You can't have that. A comment has to be written with // not / /.
Go through your code and correct these and see if things get any better.
This code had two part. this is part 1
#include <IRremote.h>
#include <Servo.h>
// *********************** Defined motor pin ********************* ****
int MotorRight1 = 5;
int MotorRight2 = 6;
int MotorLeft1 = 10;
int MotorLeft2 = 11;
int counter = 0;
const int irReceiverPin = 2; // OUTPUT signal of the infrared receiver is connected to the pin 2
// *********************** Set detected IRcode ****************** *******
long IRfront = 0x00FFA25D; // forward code
long IRback = 0x00FF629D; // Back
long IRturnright = 0x00FFC23D; // turn right
long IRturnleft = 0x00FF02FD; // turn left
long IRstop = 0x00FFE21D; // Stop
long IRcny70 = 0x00FFA857; // CNY70 self-propelled mode
long IRAutorun = 0x00FF906F; // ultrasound self-propelled mode
long IRturnsmallleft = 0x00FF22DD;
// ************************* Defined CNY70 pin ******************* *****************
const int SensorLeft = 7; // left sensor input pin
const int SensorMiddle = 4; // the Sensor input pin in
const int SensorRight = 3; // right sensor input pin
int SL; // left sensor status
int SM; // in the sensor state
int SR; // right sensor status
IRrecv irrecv (irReceiverPin); // the definition IRrecv object to receive infrared signals
decode_results results; // decoding results on decode_results structure result variable
// ************************* Definition ultrasound pin ****************** ************
int inputPin = 13; // define the ultrasound signal reception pin rx
int outputPin = 12; // define the ultrasonic signal transmitter pin 'tx
int Fspeedd = 0; // in front of the distance
int Rspeedd = 0; // the right distance
int Lspeedd = 0; // left distance
int directionn = 0; // = 8 = 2 Left = Right = 6
Servo myservo; // set myservo
int delay_time = 250; // servo motor steering stability time
int Fgo = 8; // forward
int Rgo = 6; // turn right
int Lgo = 4; // turn left
int Bgo = 2; // reversing
// ************************************************ ******************** (SETUP)
void setup ()
Serial.begin (9600);
pinMode (MotorRight1, OUTPUT); // pin 8 (PWM)
pinMode (MotorRight2, OUTPUT); // pin 9 (PWM)
pinMode (MotorLeft1, OUTPUT); // pin 10 (PWM)
pinMode (MotorLeft2, OUTPUT); // pin 11 (PWM)
irrecv.enableIRIn (); // start infrared decoding
pinMode (SensorLeft, INPUT); // define the left sensor
pinMode (SensorMiddle, INPUT) ;// definition sensor
pinMode (SensorRight, INPUT); // define the right sensors
digitalWrite (2, HIGH);
pinMode (inputPin, INPUT); // definition ultrasound input pin
pinMode (outputPin, OUTPUT); // definition ultrasound output pin
myservo.attach (9); // define the servo motor output 5th pin (PWM)
// ************************************************ ****************** (Void)
void advance (int a) // forward
digitalWrite (MotorRight1, LOW);
digitalWrite (MotorRight2, HIGH);
digitalWrite (MotorLeft1, LOW);
digitalWrite (MotorLeft2, HIGH);
delay (a * 100);
void right (int b) // turn right (single wheel)
digitalWrite (MotorRight2, LOW);
delay (b * 100);
void left (int c) // turn left (single wheel)
digitalWrite (MotorLeft2, LOW);
delay (c * 100);
void turnR (int d) // turn right (two-wheeled)
digitalWrite (MotorRight1, HIGH);
delay (d * 100);
void turnL (int e) // turn left (two-wheeled)
digitalWrite (MotorLeft1, HIGH);
delay (e * 100);
void stopp (int f) // stop
delay (f * 100);
void back (int g) // Back
delay (g * 100);
void detection () // measuring three angles (front left right)
ask_pin_F (); // read in front of the distance
if (Fspeedd <10) // If the front of the distance is less than 10 cm
stopp (1); // Clear the output data
back (2); // back 0.2 seconds
if (Fspeedd <25) // If the front of the distance is less than 25 cm
ask_pin_L (); // read the left distance
delay (delay_time); // wait for the servo motor stable
ask_pin_R (); // read the right distance
if (Lspeedd> Rspeedd) // if the left distance is greater than the right distance
directionn = Lgo; // go left
if (Lspeedd <= Rspeedd) // if the left distance is less than or equal to the right side of the distance
directionn = Rgo; // right away
if (Lspeedd <15 && Rspeedd <15) // if the left distance and right distance are less than 10 cm
directionn = Bgo; // walk backward
else // add, such as in front of more than 25 cm
directionn = Fgo; // forward
void ask_pin_F() // measure out the front of the distance
myservo.write (90);
digitalWrite (outputPin, LOW); // let the ultrasonic transmitter Low Voltage 2¦Ìs
delayMicroseconds (2);
digitalWrite (outputPin, HIGH); // ultrasonic transmitting high voltage 10¦Ìs, at least 10¦Ìs
delayMicroseconds (10);
digitalWrite (outputPin, LOW); // maintain ultrasonic transmitter low voltage
float Fdistance = pulseIn (inputPin, HIGH); // read differential difference
Fdistance = Fdistance/5.8/10; // time to distance distance (unit: cm)
Serial.print ("F distance:"); // output distance (unit: cm)
Serial.println (Fdistance); // display distance
Fspeedd = Fdistance; // distance read Fspeedd (speed)
void ask_pin_L () // measure out the left distance
myservo.write (177);
delay (delay_time);
float Ldistance = pulseIn (inputPin, HIGH); // read differential difference
Ldistance = Ldistance/5.8/10; // time to distance distance (unit: cm)
Serial.print ("L distance:"); // output distance (unit: cm)
Serial.println (Ldistance); // display distance
Lspeedd = Ldistance; // distance reads Lspeedd (left-speed)
void ask_pin_R () // measure out the right side of the distance
myservo.write (5);
delay (delay_time);
float Rdistance = pulseIn (inputPin, HIGH); // read differential difference
Rdistance = Rdistance/5.8/10; // time to distance distance (unit: cm)
Serial.print("the R distance: "); // output distance (unit: cm)
Serial.println(Rdistance); // display distance
Rspeedd = Rdistance; // distance read into Rspeedd (right speed)
Part 2
// ************************************************ ****************************** (LOOP)
SL = digitalRead (SensorLeft);
SM = digitalRead (SensorMiddle);
SR = digitalRead (SensorRight);
// ************************************************ *************************** normal remote mode
if (irrecv.decode (& results))
{// Decoding successful, receive a set of infrared signals
if (results.value == IRfront) // forward
advance (10) ;// forward
if (results.value == IRback) // Back
back (10) ;// Back
if (results.value == IRturnright) // right turn
right (6); // turn right
if (results.value == IRturnleft) // left turn
left (6); // turn left);
if (results.value == IRstop) // stop
// ************************************************ black self-propelled mode the *********************** cny70 mode: LOW white:
if (results.value == IRcny70)
while (IRcny70)
if (SM == HIGH) // in the sensor in the black areas
if (SL == LOW & SR == HIGH) // left black right white to turn left
analogWrite (MotorLeft1, 0);
analogWrite (MotorLeft2, 80);
else if (SR == LOW & SL == HIGH) // left white right black, turn right
analogWrite (MotorRight1, 0) ;// turn right
analogWrite (MotorRight2, 80);
else // both sides are white, straight
analogWrite (MotorLeft1, 200);
analogWrite (MotorLeft2, 200);
analogWrite (MotorRight1, 200);
analogWrite (MotorRight2, 200);
else // in the sensor in the white areas
if (SL == LOW & SR == HIGH) // white left black right, quick left turn
else if (SR == LOW & SL == HIGH) // left white right black, quick right turn
else // are white, stop
irrecv.resume ();
Serial.println (results.value, HEX);
results.value = 0;
// ************************************************ the *********************** ultrasound self-propelled mode
if (results.value == IRAutorun)
while (IRAutorun)
myservo.write (90); // the servo motors regression ready position ready for the next time measurement
detection (); // measure the angle and the judgment to where to move in one direction
if (directionn == 8) // if directionn (direction) = 8 (forward)
irrecv.resume ();
results.value = 0;
advance (1); // normal ahead
Serial.print ("Advance"); // display direction (forward)
Serial.print ("");
if (directionn == 2) // if directionn (direction) = 2 (reverse)
irrecv.resume ();
results.value = 0;
back (8); // reverse (car)
turnL (3); // move slightly to the left (to prevent stuck in a dead alley)
Serial.print ("Reverse"); // display direction (reverse)
if (directionn == 6) // if directionn (direction) = 6 (turn right)
irrecv.resume ();
results.value = 0;
back (1);
turnR (6); // turn right
Serial.print ("Right"); // display direction (turn left)
if (directionn == 4) // if directionn (direction) = 4 (turn left)
irrecv.resume ();
results.value = 0;
back (1);
turnL (6); // turn left
Serial.print ("Left"); // display direction (turn right)
irrecv.resume ();
results.value = 0;
irrecv.resume (); // continue to the next set of infrared signals received
I tried a lot .Please compile the sketch only if possible for me . I am traveling at the end of this month .please and upload it.
If you tried a lot then you must have a lot of error messages. Start with the first one. What does it say? Copy the error messages and paste them here if you need help understanding them.
kevinlol:
I'm sorry, but that's just not what happens here. There is a section of the forum called Gigs and Collaborations where you can offer to pay someone to write code for you. This section is for getting free help with the code YOU write. Nobody here writes code for free.
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x75
